![]() | Home > Maintenance & Modifications > 2010 TDV8 For Off road use (Morocoo, Tunisia, Lybia) |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Sump guard is the same.
verydisco Member Since: 06 Apr 2006 Location: The South Posts: 75 ![]() ![]() |
thanks for the rock slider idea
Hi, any help mates ?
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Echo the remarks about the sliders, also get some of the yellow clips to hold on the plastic door trim. Also the plastic air dam at the front is easily damaged as per the one seen on the left of this pic (not sure if the 2010 model has the same)
As a tempory measure you could get shortend sensor rods fitted to put the ride hight up a bit, a lot cheaper than Matzker! Sons of dogs come hither and get flesh Clan Cameron |
