Home > Technical > faults |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 |
Its an all stop then?
Fri Jan 22 2010 1:42pm |
stephenl242 Member Since: 02 Jul 2008 Location: east sussex Posts: 12 |
fuses are all fine . to worried to drive as dont know whats going to pack up next |
Fri Jan 22 2010 1:45pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Sounds pretty serious if all those systems are failing. How long have you had the car? Did you buy from a Land Rover dealer? Do you have any sort of Dealer or extended warranty? It sounds like you need to get it in to a dealer or specialist to get checked out. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri Jan 22 2010 1:50pm |
Battery needs replacing?
Ofcourse All hail Shmoogle the oracle of all thing RRS 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Fri Jan 22 2010 1:52pm |
Fri Jan 22 2010 1:55pm |
its got new battery faults cleared , then everything started to pack up |
Fri Jan 22 2010 1:56pm |
See, Endjin, I told you!
Fri Jan 22 2010 2:05pm |
nothing shorted was watching them while they put it in they put spare battery on to keep power on while being done |
Fri Jan 22 2010 2:21pm |
I take it all back.... You're obviously just as big a numpty as the rest of us @Stephen, If these faults have only appeared since the Batt was replaced then I strongly suggest you take the car back to whomever installed the new battery. Were they a LR Dealer or specialist? If not then I'd seek out your nearest specialist as per my earlier post. Good Luck M8. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Fri Jan 22 2010 2:28pm |
no they started before thats why changed battery hoping to sort it but failed thanks for your help anyway |
Fri Jan 22 2010 2:37pm |
Are all the lights OK, no blown lamps anywhere around the car, especially in the rear clusters? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jan 22 2010 4:27pm |
all lights ok just dont know whats going to stop working next |
Fri Jan 22 2010 4:47pm |
Graemereeper Member Since: 25 May 2009 Location: Up a mountain somewhere Posts: 35 |
If it solved the issues when replacing the battery, then the faults came back after a while, would seem to me to be a discharging/charging fault. Best have your alternator looked at, could be voltage regulator. |
Sat Jan 23 2010 11:47am |
