![]() | Home > Technical > faults |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
New alternator fitted. Problem solved. TDV6 - gone
RRSSTEVE Member Since: 17 Jan 2010 Location: POOLE DORSET Posts: 15 ![]() ![]() ![]() |
Hi try disconnecting battery leaving for 2 minutes and reconnecting also check read and clear faults if faults reoccur check fault codes again this will narrow it down. meanwhile check for water ingressto passenger footwell, ccould be wet body control unit/ fusebox. make sure sunroof drains not blocked open sunroof poor in some water at edge and make sure it comes out just behind front wheel |
