![]() | Home > Maintenance & Modifications > Coolent Refilling |
After topping up you may want to keep an eye on things. If the water level keeps on dropping and there are no obvious leaks, I would suggest the cooling system to be pressure tested for condition and leaks. Malaysia Boleh!
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
Thanks Tim and Bobby.
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
So... let me ask a similar question again, if you don't mind.
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
look at the links, is from our web dedicated in Spain to LRS, but RRSS are the same mechanicals, use google traslator to understand what rFollia says.
Anti-freeze :
