Home > Maintenance & Modifications > Coolent Refilling |
After topping up you may want to keep an eye on things. If the water level keeps on dropping and there are no obvious leaks, I would suggest the cooling system to be pressure tested for condition and leaks. Malaysia Boleh!
Mon Jan 18 2010 1:50am |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 |
Thanks Tim and Bobby.
Thu Jan 21 2010 8:40am |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
So... let me ask a similar question again, if you don't mind.
Sun Aug 29 2010 4:56pm |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 |
look at the links, is from our web dedicated in Spain to LRS, but RRSS are the same mechanicals, use google traslator to understand what rFollia says.
Fri Jun 03 2011 12:17am |
Anti-freeze :
Fri Jun 03 2011 1:45am |
