![]() | Home > Technical > Air suspension query? |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Very normal don't worry.......does it I think when in access or normal........ |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Cool, any ideas why? |
It vents the pressure.
Ok but wouldnt this drop the extra bit every time? I always put it in access mode as the mrs is only 4'10'' and would have to parachute out if not |
It doesn't do it every time. If you have the Adaptive Bi-Xenons they do a little dance when you switch them on and sometimes when you are stopped in traffic at night you will see the ordinary Bi-Xenons doing a self-levelling check dance! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Ok thanks Tim so much to learn, Ha ha |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
It's also possible that you opened the door to get out before the car had fully settled into access mode. In that case, it would stop lowering until you closed all the doors, and then resume.
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
Just think of it as wind |
ordnasg Member Since: 08 Sep 2009 Location: Croatia Posts: 7 ![]() |
Few months ago I almost bought my self a RRS but the car wasn't in good shape so I have passed this opportunity. But I'm following this forum and still hopping to find a nice one.
A newbie myself so I may be wrong but I believe it's only an issue if they are not left in access mode when left parked for a long period like a couple of months. |
When the vehicle is parked, the air suspension control module 'wakes up' two hours after the ignition was last switched off and then once every six hours. The vehicle height is checked and if the vehicle is not level within a pre-set tolerance, small downwards height adjustments may be made automatically. |
Thank you for your answers. So, there is no need to worry - over the night and if car is not used for day or two (or more) use the access mode, else it's safe to leave it in normal mode.
Yes, no need to worry! |
