![]() | Home > Maintenance & Modifications > Winches and more.... |
Graemereeper Member Since: 25 May 2009 Location: Up a mountain somewhere Posts: 35 ![]() ![]() ![]() |
If you fit the winch, the front bumper will need to be cut, which means you lose your front parking sensors. The other problem can be the ACC sensor which were removed from the G4 sports because of the locale of the winch setting it off. If this is disconnected you will then lose your cruise control.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Thanks for the info Greame doesn't sound too bad, and do-able. Not really fussed about the ACC, so could disconnect that quiet happily.
Just checked I don't have ACC, only cruise control so should have no issues there either as the radar sensor isn't installed |
NJF Member Since: 05 Dec 2009 Location: Normally on DISCO3.CO.UK Posts: 95 ![]() ![]() ![]() |
I don't know the SC, but I'd guess that the RAI issue could be down to the fact that this model uses the air intake on each side of the car and the RAI is available only for the RHS. |
VA had a winch fitted and had the front PDC. I think you will find also on the SC the LHS vent/intake is a dummy. The vent isn't difficult to remove so you could take them both off to see! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tim,
Hi - Mine was a normal TDV6. The only reasons for not being able to fit a winch are, 1. your adaptive cruise control will have be disabled, and 2. your front parking sensors will need to be disabled. I got around the front parking senors by leaving them active and covering up the sensors with butyl tape - not ideal but seemed to work.
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
On my G4 RRS the ACC works (sadly) and the park sensors don't. It's in the dealers this week for some repairs, I've asked them to look at the park sensors to see if they can get them to work. Not holding my breath though Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne. |
Cheers for the info Guys!!
I only covered up the 2 redundant sensors and whilst occasionally I had problems with beeping mostly it worked well. 2005 Zambezi TDV6 - Gone but not forgotten
