![]() | Home > General > Rent a car trailer |
Yellow pages - trailer rentals - look for the Indespension franchise - they build, rent and sell all kinds of trailers and fit towbars and are a nationwide franchise. Quick release tow hook would be OK and you would need to have single electrics for the trailer lights. Trailer centre would be best to advise you.
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
Yes the quick release towbar would be more than adequate and yes you would need electrics and trailer board. Towed our boat from Scotland with the Sport, weight of boat and trailer approx 2.7 tonnes.
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
top guys! Thanks! Range Rover Vogue ‘17 TDV6
One more thing... Is the electrics install a do it yourself or too complicated? Range Rover Vogue ‘17 TDV6
Quite few seem to have done it themself, the only thing you will need is a £100 visit to the dealer (or get hold of an Autologic program) to enable the trailer lighting repeater icon on the dash IIRC. Trailer rental places can do it for you 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks Tim, I guess that if you have to go to the dealer anyway...you might have them do the install.. Range Rover Vogue ‘17 TDV6
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Towing hitch is up to the job no probs, not sure if some enablement is needed though on electrics as their is a saftey feature that will not allow height to be changed with trtailer attached
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Electrics are a DIY certainly upto MY09, dash icon works and height adjusts - only SW issue i was informed of was mod to turn rear fogs off when electrics in - in case you were towing a caravan - in order to turn off the 'glare' of the fogs in the rear view mirror |
Lespes
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Company called Trailoway not a million miles away from you rent trailers. They are based in Walton on Thames Surrey. |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 ![]() ![]() ![]() |
The only laws that apply to this outfit is that "a perdon who first passed their test after 1st January 1997 is restricted to a combined Maximum Authorised Mass, (MAM) of 3500 kg.
4wheeldriver
Landlord
