Home > Technical > How do I upgrade SatNav software? |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 |
philmw
Fri Jan 08 2010 4:08pm |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 |
is it just me or can you only put part of the post code in the MY10 satnav, so that you can get nearly there. Sure in MY06 that full post code could be inputted purple people eater
Mon Jan 11 2010 5:44pm |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 |
Whats the cost tornado? Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Mon Jan 11 2010 7:01pm |
I bought them from a LR main stealer (Ascot Sytner) on Ebay for £139 plus p&p - very good service. |
Mon Jan 11 2010 8:25pm |
jetblasters Member Since: 09 Oct 2007 Location: Heathrow Posts: 31 |
I was told my a friend that you can get the discs here:
Sun Jan 31 2010 11:51am |
TomK Member Since: 11 Apr 2010 Location: Innsbruck Posts: 5 |
Hi, I have bought a 05 RRS and will get it on friday. Now my question is: Do I need the CD always or only one time when I am updating ?
Wed Apr 14 2010 7:29pm |
always - the disc has to be left in the disc drive. |
Wed Apr 14 2010 9:10pm |
kman Member Since: 25 Nov 2005 Location: Bedfordshire, UK Posts: 89 |
this might be a bit of a dumb question, but where is the drive for the nav disc? Can't see it in the glove compartments and I don't think its the slots where the audio cds load? |
Wed Jun 02 2010 4:59pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Under LH front seat |
Wed Jun 02 2010 5:49pm |
AJS Member Since: 25 Mar 2010 Location: OXFORDSHIRE Posts: 9 |
you have to make sure you have the correct disc for the correct vehicle.
Thu Jun 03 2010 9:29am |
thanks but next question - how do I get the plastic cover that seems to be concealing the drive off? Tried just pulling it off but seems to screwed on in some way - or do i need to use more force? |
Sat Jun 05 2010 10:59am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
I'm sure if I tried to remove the cover I would break something. I always reach from the back of the seat. If you put the seat all the way forward and up you have enough room to eject and remove the disk. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Sat Jun 05 2010 12:17pm |
I think it does just pull off but as FD says - seat forward and access from the rear |
Sat Jun 05 2010 12:33pm |
