Home > Technical > HDC Reported Fault |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 |
I'm getting the same message flash up occasionally on mine, but after using the HDC yesterday I know there's no fault in it, so I'm a bit puzzled as to why it's coming up. Having only had the car 2 weeks I'm just adding it to the list of 'issues' to be looked at by Stratstones when I give it back to them for a day to sort everything out, be great if I could give them a definitive "you need to do this....." if it's a known problem area.
Fri Jan 01 2010 5:19pm |
dans1v Member Since: 21 Apr 2008 Location: SHFFFIELD Posts: 13 |
i would agree lets see if any of the others come up with any ideas for us? Java Black RRS HSE TDV6 Stormers, tints, steps the usual stuff.. |
Fri Jan 01 2010 9:23pm |
shuzzy Member Since: 02 Aug 2009 Location: West Yorkshire Posts: 143 |
I have recently started to get the same thing, most of the time when I start it up after it's been parked up for a while. It will flash up for a couple of seconds that I have a HDC fault, but then it disappers straight away. Looks like it mught be one of them RRS 'chracteristics' again...... |
Fri Jan 01 2010 10:30pm |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
I am sure this is related to a low battery voltage on startup. Has anyone tried charging their battery or replacing it?
Fri Jan 01 2010 10:58pm |
I had a new battery fitted a few months ago, so this shouldn't have any bearing on things now. |
Sat Jan 02 2010 2:06am |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
I have had this over on Freel2 and on the FL2 it's related to a sensor on the haldex unit and it only appears in very cold weather, but on Disco3 it was related to battery issues |
Sat Jan 02 2010 9:13am |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
chaps...
Sat Jan 02 2010 3:42pm |
Also don't forget that low temperatures can kill a battery overnight so if you have had very low temperatures (mind you we have had down to -12c here some nights recently but my RRS has had no problems starting, unlike my 90 which is garaged and the battery can only just start the car after a really cold night, but after a run and the car's inside has warmed up then it starts no problems at all) then that will reduce the efficiency of your battery and could cause these warnings to show up 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jan 02 2010 5:01pm |
Looks like a new battery then. Mine popped the message up today after a particularly cold night and 'someone' leaving the interior reading lights switched on overnight Will have to see if I can get the dealer to swap it under their warranty (doubtful, but worth a try). Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne. |
Sat Jan 02 2010 7:02pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Cool |
Sat Jan 02 2010 10:10pm |
