Home > Australia & New Zealand > Gas Injection Systems
Jimmy Salsa
Australia
Over the pas couple of months I have founfd myself doing some work vicariously with Gastek recently. Those of you who spent some time at the Land Rover Expo at Castle Hill earlier in the year will remember them from the fantastic demo they did in the centre field with the big arch.
The more I find out about this system the more intrigued I get and am seriously looking at having one installed in the sport.
Has anyone looked into it or had it installed? 'Black Betty' Java Black RRS 07 TDV6
Post #243833 Fri Nov 27 2009 12:46pm
Jimmy Salsa
Australia
Just an update on the Gas injection status.
It appears that they are yet to install a system on a sport. Apparently there are a few issues finding enough space under the engine bay, but the guys have been fantastic and should be getting back to me this week with a plan of attack. Fingers crossed it will be able to be installed before xmas so I can have a play over the break while on hols.
Will keep all y'all updated on the progress. 'Black Betty' Java Black RRS 07 TDV6
Post #245323 Mon Dec 14 2009 7:23am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
What does it aim to give you Jimmy l?
Post #245335 Mon Dec 14 2009 9:30am
Jimmy Salsa
Australia
Looking at 20% increase in power (minimum) and about the equivalent in fuel economy.
According to their tech info the needle injection technology is controlled by an independent CPU that interprets usage and injects the gas into the fuel mix up to 100 times a minute to increase the fuel burn rate from around 80% up to 95%.
The end result is an increase in power right across the rev range plus little-to-no black smoke at the tailpipe as the majority of diesel gets burnt.
You can also modify the CPU to change the power vs fuel economy. 'Black Betty' Java Black RRS 07 TDV6
Post #245338 Mon Dec 14 2009 9:46am
2nd Rower
What is the benefit of this over a chip?
Post #245357 Mon Dec 14 2009 11:12am
Jimmy Salsa
Australia
There are a range of benefits including reduced wear and tear on the engine, significantly reduced emissions, more control over unit settings and better fuel economy over most conventional chip systems.
The minimum 20% is just that. On a TD5 they got a 40% increase in power output.
Can't wait to see what it does to the RRS Very Happy 'Black Betty' Java Black RRS 07 TDV6
Post #245363 Mon Dec 14 2009 11:31am
Jimmy Salsa
Australia
A quick update on the Gas Injection - looks like a no go for the sport.
Due to the lack of space under the hood and under the car, the only option for the small gas tank is to remove the spare and put it there.
This in turn means locating the spare in the boot which is already way too small, or putting on some racks and mounting it up top. Neither of these appeal enough for me to warrant doing it so I'm back to investigating chip options.
Anyone got any good recommendations? 'Black Betty' Java Black RRS 07 TDV6
Post #252125 Wed Jan 27 2010 11:58am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Naturally all systems vary somewhat, however, my dealer has had a S/C FFRR in twice now............for 2 new engines!! Shocked Shocked
As LR do not support LPG under their warranty, its down to you as an owner.
Now arguably this could be seen as a one off, but the numbers don't add up as he has now seen {many} through his door with Knackered engines, all down to gas conversions. It seems the S/C engine hates gas!!
Just a word of warning before you spend out the 1-2k for what could cost you an additional �8k+ for a new engine Wink Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #252129 Wed Jan 27 2010 12:33pm
Jimmy Salsa
Australia
Thanks for the heads up.
With the LPG and LRA Warranty, do you know any details about what they will cover?
This is not a conversion as such to LPG but a small micro tank and patented needle injection system that injects LPG into the diesel mix replacing about 25-30% of the diesel with LPG. You don't have to change any other mechanicals as the injection takes place inline through the air intake system.
The result is a greatly increased burn rate and a lot less pollutants. 'Black Betty' Java Black RRS 07 TDV6
Post #252286 Thu Jan 28 2010 3:00am
