![]() | Home > Australia & New Zealand > Gas Injection Systems |
Jimmy Salsa Member Since: 03 Mar 2009 Location: Hunter Valley Posts: 257 ![]() ![]() |
Over the pas couple of months I have founfd myself doing some work vicariously with Gastek recently. Those of you who spent some time at the Land Rover Expo at Castle Hill earlier in the year will remember them from the fantastic demo they did in the centre field with the big arch.
Just an update on the Gas injection status.
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
What does it aim to give you Jimmy l? |
Looking at 20% increase in power (minimum) and about the equivalent in fuel economy. According to their tech info the needle injection technology is controlled by an independent CPU that interprets usage and injects the gas into the fuel mix up to 100 times a minute to increase the fuel burn rate from around 80% up to 95%. The end result is an increase in power right across the rev range plus little-to-no black smoke at the tailpipe as the majority of diesel gets burnt. You can also modify the CPU to change the power vs fuel economy. 'Black Betty' Java Black RRS 07 TDV6 |
What is the benefit of this over a chip? |
There are a range of benefits including reduced wear and tear on the engine, significantly reduced emissions, more control over unit settings and better fuel economy over most conventional chip systems. The minimum 20% is just that. On a TD5 they got a 40% increase in power output. Can't wait to see what it does to the RRS ![]() |
A quick update on the Gas Injection - looks like a no go for the sport.
Thanks for the heads up.
