![]() | Home > Technical > Locked in low range |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231 ![]() ![]() ![]() |
Hi Bobby, I manged to get the following fault codes from the dealer today:
Hmm... OK. I don't have a vast library or anything but from my records, P0806 is related to the Rear Drive Axle and Differential!: P0806-00 Clutch Position Sensor Circuit Range/Performance � Mismatch of actual and expected/calculated actuator position. Internal differential actuator error. Calibrate the clutch and range change mechanism using the approved diagnostic system. If the problem persists, renew the differential actuator. P0195 I cannot find, sorry. However, there is a P091500 : Gear Shift Position Circuit Range/Performance � Gear shift position sensor circuit short circuit to ground � Gear shift position sensor circuit high resistance � Gear shift position sensor failure Refer to the electrical guides and check the gear shift position sensor circuit. Hope the above helps. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
@ Bobby
Wholeheartedly agree 640, Land Rover Australia, and a some of the dealers, don't seem to know their ar ![]() ![]() I'm not an engineer, but am I missing something - If the error codes are pointing towards the listed sensors, why is the dealer replacing the transfer box? |
Your guess is as good as mine. I'll be asking LR that tomorrow now that Bobby has given me more details. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres. |
I shouldn;t be so surprised.... considering my car had a faulty steering angle sensor, I never asked them why they replaced the steering rack. Or when they replaced the entire steering column why didn't they replace the steering angle sensor at the same time.. the list goes on... |
Please gentlemen,
But what about the detail of the guess work |
Bobby, your input is truly magnificent! |
Just contributing my 2 cents worth... |
Might just be a coincidence but in the 2 days since sending my letter to the National Customer & Technical Support Manager at LRA, I have received 3 phone calls and 4 emails, the last of which stated that they had fixed my car and would be ready for collection tomorrow, subject to a final test drive.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Hoping the news is good |
