Home > Technical > Normal Wiper Operation ??? |
RRS_TT Member Since: 30 Apr 2009 Location: Port of Spain Posts: 15 |
Tue Dec 08 2009 12:52am |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 |
Definitely not normal but I have no idea where this could come from.
Tue Dec 08 2009 8:03am |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
mine dont do that, i do feel your pain however small things like this really annoy me |
Tue Dec 08 2009 8:42am |
RANGE_LOVER Member Since: 01 Jun 2009 Location: London Posts: 306 |
Have a look at where the rear view mirror is. There should be a black case that comes apart. Inside is teh module for the rainsensing wiper. Now disconnect it (make sure the car is turned off) and then reconnect and a make sure the wires are not knotted. I had this issue after autoglass changed my windscreen and it fixed the problem. As per the above post ensure that the area which covers the rainsensing wiper on teh windscreen outside is free from any road grime etc. Then place your wipers on auto and turn the car on. It should help. Failing that i really cant help you. |
Tue Dec 08 2009 10:20am |
Well, I have doe all what you said, including disconnecting the rain sensor, but to no avail, I am still getting a single wipe on both the front and rear wipers, on start up and switching off. HELP !!!!!!!! |
Fri Dec 11 2009 10:19pm |
