Home > Technical > Normal Wiper Operation ???
RRS_TT
Trinidad And Tobago 2006 Range Rover Sport TDV6 HSE Java Black
I am just getting to know my recently purchased 2006 RRS, and my front and rear wipers come on once everytime I switch on or off my ignition. I am almost sure that it did not do this before. I have tried reading the manual and setting the wiper switch in different positions, but to no avail.
Is this normal ? Thanks for any help !
Gerry
Post #244794 Tue Dec 08 2009 12:52am
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Definitely not normal but I have no idea where this could come from. Question
Sure the rear wiper is turned off? Even if it is: Dos the rear wiper come on when you are in reverse or just right at the start?
Perhaps your rain sensor is dirty, try cleaning the windscreen at the sensor, perhaps there is some oil or something...
This is really weird. I mean, it would be fine if you lived in GB, the wipers there come on at start because it is always raining! Thumbs Up Mr. Green RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #244800 Tue Dec 08 2009 8:03am
I suspect it's the same thing that happens to my Fl2's
only cure i have found is to leave them switched off until it rains then pop them to auto
LR looked at it a few times, no fault found Neutral
Saves the risk of scratching the screen due to dry wiping a piece of grit and makes the blades last longer Thumbs Up
Post #244803 Tue Dec 08 2009 8:13am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
mine dont do that, i do feel your pain however small things like this really annoy me Laughing
Post #244812 Tue Dec 08 2009 8:42am
RANGE_LOVER
Have a look at where the rear view mirror is. There should be a black case that comes apart. Inside is teh module for the rainsensing wiper. Now disconnect it (make sure the car is turned off) and then reconnect and a make sure the wires are not knotted. I had this issue after autoglass changed my windscreen and it fixed the problem. As per the above post ensure that the area which covers the rainsensing wiper on teh windscreen outside is free from any road grime etc. Then place your wipers on auto and turn the car on. It should help. Failing that i really cant help you. Thumbs Up
Post #244828 Tue Dec 08 2009 10:20am
RRS_TT
Well, I have doe all what you said, including disconnecting the rain sensor, but to no avail, I am still getting a single wipe on both the front and rear wipers, on start up and switching off. HELP !!!!!!!! Big Cry Big Cry Big Cry Big Cry
Post #245154 Fri Dec 11 2009 10:19pm
