Home > Technical > Bluetooth now not working
Richchad
Bluetooth in my new 2 week old 2010 RRsport was working fine up until today but now shows no phone fitted, and phone cannot see the device "Landrover" Sad
When I do a phone search to find other devices it cannot see any, does this mean the Bluetooth connection in the car has packed up? Question https://www.plus.net/refer.php?strReferral...d093cba6a7
Gone - RRSPORT TDV6 HSE
Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course.
Post #244276 Thu Dec 03 2009 1:34pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
used happen to me on my 2005 TD6 - simplest solution was to disconnect and reconnect the positive terminal on the battery for a second. It then reset itself. Hardly a hi-tech solution for such an expensive car but what can you do? try it anyway and see what happens RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #244445 Fri Dec 04 2009 5:39pm
Richchad
Thanks for that Kevin, just went out to try it again, and guess what it now works had to put code in again to get it to connect, didn't give me that option yesterday, just kept trying to connect but couldn't see the Landrover device.
So don't know what that was really, one of the wonders of owning a Range Rover Sport I guess. Confused
As a last resort will give your method a try if it happens again and doesn't want to connect, although I am worried what other problems I might throw up by disconnecting the battery. Shocked https://www.plus.net/refer.php?strReferral...d093cba6a7
Post #244449 Fri Dec 04 2009 5:54pm
Misery
Tried all that and the fuses, eneded up having to get a new bluetooth moduel. If that is the case go to Nick at yeovil LR he was the cheapest. Thumbs Up
An easy DIY but hope you have small hands. Shocked
Post #244476 Fri Dec 04 2009 9:57pm
MAW
Popping the battery terminal resets a lot of other stuff too - best off with a SW disconnect / delete & re pairing IMO
Post #244479 Fri Dec 04 2009 10:16pm
Lookers Park Royal
Iphone? Neutral
Post #244527 Sat Dec 05 2009 3:56pm
MAW
Question Confused
Post #244539 Sat Dec 05 2009 5:59pm
hario69
What does a SW disconnect delete and re pair involve step by step?
Sorry for my ignorance!
Post #245599 Tue Dec 15 2009 10:09pm
