Home > Technical > dash lights flickering, no starting |
I would check what else has ben done regarding mods before you got hold of this car. Have you tried a soft re-set? you do this by locking, unlocking, locking, unlocking using the remote key. 2005 Zambezi TDV6 - Gone but not forgotten
Sun Nov 22 2009 10:57am |
ardler_dan Member Since: 22 Nov 2009 Location: Sussex, UK Posts: 8 |
The car is standard other than a tracker which is very badly fitted under the passenger dash (I have temp removed this to get it out of the question.
Sun Nov 22 2009 11:04am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
What year and model RRS? |
Sun Nov 22 2009 4:01pm |
2006 2.7 TDV6
Sun Nov 22 2009 4:09pm |
The batteries have been responsible for a LOT of these types of faults - maybe a good place to start as the age fits - My first RRS wasn't much over a year old when it needed a new battery |
Sun Nov 22 2009 4:11pm |
does it have to have a specific model like some other cars or will any that matches the output/dimensions etc do the trick? |
Sun Nov 22 2009 4:17pm |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Alternator maybe..... |
Sun Nov 22 2009 7:39pm |
I'm gunna get a 019 battery tomorrow, and see how it takes to it, as if the alternator is flattening the battery that badly then a new battery should be on the cards anyway.
Sun Nov 22 2009 7:58pm |
It shouldn't without load enabled |
Sun Nov 22 2009 10:18pm |
Has to be a short or partial short to earth(bodywork) I would think, unplug bits or pull fuses one at a time till the current drag goes. Works for me on the lifts I fix (sometimes ) |
Sun Nov 22 2009 10:50pm |
new battery fitted, rear number plate light bulb changed.
Mon Nov 23 2009 4:56pm |
Isn't there a way of clearing fault codes that maybe introduced by a bad battery level - valid faults would then re report ? |
Mon Nov 23 2009 5:45pm |
yes, these procedures have been carried out, which have removed all the invalid codes regarding voltage levels etc. the codes above are re-accuring faults. |
Mon Nov 23 2009 6:39pm |
Davidch Member Since: 22 Jul 2009 Location: Kent Posts: 40 |
Did you manage to sort out these codes? RRS Supercharged HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
Mon Jan 18 2010 12:48pm |
