![]() | Home > Maintenance & Modifications > 20"'s in the snow |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
not used the 20" in snow, but I have a set of 19" rims fitted with Goodyear Wrangler MT/R tyres and they are great in the snow, not sure how they are on ice tho.
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 ![]() ![]() ![]() |
I have two 20" sets, but not tried in the snow yet. I will let you know asap. My gallery: http://www.rrsport.co.uk/gallery/thumbnails.php?album=994 |
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
I was lucky enough to have a play in the snow last winter, i was amazed how well the car performed on 20" wheels, not tried the 19" so unable to compare but based on last years performance i wont be rushing out to buy any winter tyres MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
If they have the same tread pattern and compound then they'll handle the same. Check for the 'snow flake' symbol on the tyres, which indicates that they're suitable for ice and snow. Vredestein and Pirelli make good winter tyres in 20", a few others too. |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
I have 20" Vredestein on mine and must say that the car handled stunningly good on snow |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
I also have 20" Conti c.c. winter tires on mine and handle very well on snow but I guess 19" would perform even better 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 ![]() ![]() ![]() |
Ok, had 1st good snow, snowplows cleared streets and took the HSE down the road and pumped the
[quote="funnyguy1" 20"s no good and a........they said 19"s about as bad, so going looking for studded snow tires.[/quote]
Even though the width of the tyre is an important factor (255 on 19" against 275 on 20"), I absolutely agree with Leo ![]() |
Actually the wheel width has everything to do with it. The wider the tire the more they plane especially if the tires are the Conti's which came with most of the RRS's in 2009. This is snow/sheet ice country ( we can get up to 200 inches a winter) and Conti 20"'s & 19"s do not stop these cars. Because of the weight of the car it will most likely need studded snow tires. mike murphy |
The Conti sport contacts will be crap in ice/snow no matter what their size. My point is that the tread pattern and compound are more important that rim diameter. You can get really good winter tyres from Nokian, Vredestein etc in 19". |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
I'd go with the advice of the locals. TDV6 - gone
Thanks Josh! Good advice. I will ask the owner's here in Sun Valley what they use. |
