noddy
![](templates/vbnew/images/spacer.gif)
sorry, have been away from the forum for a bit chaps, but what splendid news - Doc, I knew it was worth making all the noise! congrats on keeping the faith when all around were telling us otherwise..
all I can say is: HALLELUJAH!!
Alas, it has come too late for the beloved Rimini TDV6.. sadly it has gone..
BUT happily it has been replaced with an even more beloved black Supercharged! which also knocks but at 2k miles nothing like as bad as the 22k mile diesel did. Will be booking it in for the suggested fix, and will be expecting a hatful of humble pie from the dealer.
Nod RRS Supercharged
Java/ Ivory
'94 F355, '90 M3 Evo, '95 Integrale Evo, '97 Cooper S Works, '84 911 Cab, '89 911 Speedster, '85 6R4, '59 Routemaster and something sensible for the Mrs
Tue Mar 20 2007 12:37pm |
The doc
the voice of reason wrote:Don't want to rock the boat here......but......
Firstly we have to ask why we bought a sport? if it was for the ride comfort, ultimate luxury, low cabin noise etc then sorry guys you bought the wrong model (should of spent the extra on a Range Rover)?
If however you are willing to sacrifice some of the above for, pure grunt, and excellent handling, packaged with aggressive looks then you chose right and the sport is for you.
A few facts
1. all cars make all sorts of noises, some cars are better than others at masking that noise from cabin occupants, but regardless they still make the noises
2. nobody can fix a fault that is not a fault
3. that knocking noise you ask? you mean you don't hear a similar noise on your BMW/AUDI, well hell thats because they play safe using outdated technology whilst My RRS is cutting edge (admittedly sometimes bleeding edge) but hey thats part of the Land Rover charm/ owner experience!
ARC or Active Roll Control is a major innovation in road safety devices and handling technology, no longer must we make do with suspension that is balanced between handling and comfort, now we can have both. a dynamic system that is constantly changing according to driver demand and road conditions. a system that can flick at a milliseconds notice from soft comfort to "no ! I wont let you roll this car mode", allows Granny to ride in comfort in the back on the way to the airport and then allows the driver some real fun on the way back home.
the cost, being a minor hydraulic fluid knock, a simple rule of basic physics, providing driver reassurance that the system is working to it's full potential.
or
I could stick to my boring old technology, run of the mill BMW/AUDI ?????
the technical bit..
ARC is effectively 2 halves of an anti roll bar joined in the middle by a hydraulic coupling which on demand from the Dynamic response module can immediately alter the torsion provided within the roll bar.
The module uses various sensors to determine road conditions, steering angles and roll angles combined with driver inputs along with a complex algorithm to alter the torsion through the bar by forcing more fluid in or out of the coupling, this means that fluid is force ably changing direction of flow sometimes multiple times within split seconds. Simple physics means that a water hammer or hydraulic knock is created,now should the unit not be attached to anything in space this noise would not be detectable however when attached to a vehicle it is audible. what you are hearing is not any play in any component more a resonance of noise created by the hydraulic movement within the system.
The answer (the only possible answer) have a far slower reacting solely electrical system which will with current motor technology be unable to provide the responses required, or go backwards to a non active system, sacrificing the additional safety and handling benefits this clever system provides.
In short Cars now make all sorts of noises that cars 10 years ago did not make, the problem here is that learned experience is convincing you this sound is abnormal and potentially dangerous, once you can get your head around this then you will appreciate that it's just another noise associated with the correct operation of the car just as musch as the exhaust note is.
Here endeth the lesson.
Regards
The voice of Reason.............
FYI your a CUN7.
Sun Nov 01 2009 6:44pm |
Hog
A few facts
or
the technical bit..
Regards
An impressive understanding of technology. However I would be more impressed if LR would have been able to smooth out the noise, like they dampen the diesel sound in the TDV6. That is what you expect from a car of this signature
Tue Sep 27 2016 4:30pm |
