![]() | Home > General > 2010 TDV6 or TDV8 |
emrubi Member Since: 27 Oct 2009 Location: Milan Posts: 14 ![]() ![]() |
for a 1800 pound difference would you go TDV8 instead of TDV6?
Definitely go for the TDV8.
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
My MY08 2.7 has DPF and pipes still go down, so don't think they are linked.. |
Hmm, OK |
in Italy the difference between tdv6 and tdv8 is 5k euros but tdv6 does not have dynamic response and a few other gizmos..
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
They do if you have the particle filter fitted. If not the pipes go down ! First MY10 Sports were fitted as standard with particle filters but now are an option. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather, MY07 TDV6 HSE, Zermatt Silver, Gone ----------------------------- 1964 Austin Healey 3000 2007 LR Defender 2011 VW Tiguan R Line |
Guys...
diamond Member Since: 09 Feb 2009 Location: Dusseldorf, Germany Posts: 217 ![]() ![]() ![]() |
That's strange because both old tdv6 and tdv8 were Euro4 with or without DPF.
Indeed.... I don't think they're EuroV. |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 ![]() ![]() ![]() |
Doesn't LR website have this sort of info?
LR website is much better than it used to be, but couldn't find that info there.... might be worth a look in GTR though. |
I guess meeting the euro.. compliance means that the same engine need to keep its emissions of CO2X100km below the standard requested in order to get the euro.. approval
Could be but I wouldn't assume it has actually been certified, if that's important for what tax you pay? |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
I'd rather have downturned tail pipes than a DPF......can always change the pipes later, but the dpf will cause you problems for a long time. |
