Home > General > 2010 TDV6 or TDV8
emrubi
Italy
2010 TDV6 or TDV8
for a 1800 pound difference would you go TDV8 instead of TDV6?
are the tailpipes of the 2010 V8 straight out the back or facing down as on the old tdv8?
anyone knows wether the new TDV8 is euro 5 compliant?
thanks for helping!!
Post #241341 Wed Oct 28 2009 2:35am
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
V8 every time. i thought their was 5K differance in price not £1800.
andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #241355 Wed Oct 28 2009 10:31am
Definitely go for the TDV8.
I think the TDV8 (which isn't "new" by the way, it's the same TDV8 as before) is Euro 4 compliant, not 5.
I know the new TDV6 pipes now point straight out, but not sure about the TDV8. It may now have a DPF, which would allow them to run the pipes straight out as opposed to downwards....
Someone else should be able to confirm.
Post #241356 Wed Oct 28 2009 10:34am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
My MY08 2.7 has DPF and pipes still go down, so don't think they are linked..
Post #241358 Wed Oct 28 2009 10:46am
Hmm, OK Thumbs Up MY10 TDV6 pipes definitely go straight out though Very Happy
Post #241360 Wed Oct 28 2009 10:48am
emrubi
Italy
in Italy the difference between tdv6 and tdv8 is 5k euros but tdv6 does not have dynamic response and a few other gizmos..
so if you add this optionals up to the tdv6 base price the difference is a little more then 2000 euros (1800 pounds)
Post #241368 Wed Oct 28 2009 11:19am
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
They do if you have the particle filter fitted. If not the pipes go down ! First MY10 Sports were fitted as standard with particle filters but now are an option. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #241375 Wed Oct 28 2009 11:44am
emrubi
Italy
Guys...
I'll talk to the dealer when they're back from lunchbreak... and...
get that
TDV8 ordered Very Happy
thanks lots for the fulfilling posts!!
PS. I called Land Rover UK and Italy asking about euro5 and straight pipes on tdv8.. but they did not know what to answer.. called the Germans and the answer was that:
TDV8 IS EURO5 - HAS A FAP FILTER AND HAS STRAIGHT SLASHDOWN MUFFLERS Thumbs Up
this twin turbo V8 is definetly a "Sir" engine + with a little chipping you take it to 330 horsepower and 750+ nm ... easy...
Post #241381 Wed Oct 28 2009 12:24pm
diamond
Greece 2009 Range Rover Sport TDV6 SE Alaska White
That's strange because both old tdv6 and tdv8 were Euro4 with or without DPF.
You need to check this again 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
2004 Fiat Panda 1.2 Climbing 4x4
http://www.youtube.com/watch?v=fAg4DdXAp7Y
Post #241384 Wed Oct 28 2009 12:46pm
Indeed.... I don't think they're EuroV.
Post #241386 Wed Oct 28 2009 12:51pm
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Doesn't LR website have this sort of info?
Must admit I rarely look in the right place for things. Wink
Post #241388 Wed Oct 28 2009 12:54pm
LR website is much better than it used to be, but couldn't find that info there.... might be worth a look in GTR though.
Post #241389 Wed Oct 28 2009 12:56pm
emrubi
Italy
I guess meeting the euro.. compliance means that the same engine need to keep its emissions of CO2X100km below the standard requested in order to get the euro.. approval
so.. most likely the tdv8 with FAP filter and some minor ecu adjustments can meet the euro5 compliances
.. I am just guessing here
Post #241390 Wed Oct 28 2009 12:56pm
Could be but I wouldn't assume it has actually been certified, if that's important for what tax you pay?
Post #241391 Wed Oct 28 2009 12:58pm
Leo
Kenya
I'd rather have downturned tail pipes than a DPF......can always change the pipes later, but the dpf will cause you problems for a long time.
Post #241392 Wed Oct 28 2009 12:58pm
