![]() | Home > Technical > Front suspension knocking - Not the Dynamic Response one! |
mccalia1 Member Since: 09 Aug 2009 Location: UK Posts: 368 ![]() ![]() ![]() |
There were updated Anti Roll Bar bushes released which reduced the knocking sound considerably but the RRS is subject to the occasional light knock. Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20" |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
Ive had the same noise on my car, read tested all the posts.
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Pete - Is this issue you describe fixable?? |
Yes if I fit a new rack. The knock is so slight on my car I've not replaced the rack yet.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
There you go 2nd, stop your whining!! |
enzojunior Member Since: 25 Jun 2008 Location: Sydney Posts: 26 ![]() ![]() ![]() |
Yep, it's the rack. I've had 4 sets of bushes replaced including the new style, twice. All to no avail. After the rack was replaced, going on 10,000km now, everything is perfect. Luckily this got fixed a month before the warranty expired. So, if you have the non-dynamic response knocking, the steering rack is your problem and solution. 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack... |
![]() I'll be happier when I can hear my whining over the noises the RRS "characteristically" makes!!! ![]() |
Is the new steering rack a different design, or the same as the original... i.e. is it likely to need replacing every time it wears out over anumber of years or km's!??? What kms did your problem first appear at enzo?? |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Interesting after 6 months of a continual clunk they changed the lower control arm bushes and ball joints, i had to wait for the new and improved design to be shipped from the UK. On severe bumps (your average Sydney road) i can still hear it... so do i need a second new steering rack |
