Home > Technical > Low coolant level |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Say good bye when you do thats the last you'll be seeing of her RRS TDV6 Gone but still around
Fri Dec 21 2007 10:57am |
Believe me, I will have seen plenty enough of her
Fri Dec 21 2007 11:11am |
Fri Dec 21 2007 1:01pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
mees, that screw is for bleeding air out of the system, they may have left it slightly loose after water pump change, (so you may want to go back, and kick their arses ). You can try nipping it a bit tighter, but don't over do it, as the threads are only plastic. If that doesn't stop it, the screw / seal may need replacing. Good Luck RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sat Sep 05 2009 2:34pm |
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 |
hello Textar
Sat Sep 05 2009 6:33pm |
Hi mees, now your water pump has been replaced, and YOU have tightened the bleed screw (shame on your dealer ), I would not expect to lose much coolant, but after components in the cooling system have been replaced / disturbed you may need to top up by small amounts for a while until things settle down again, then it should not need more.Hope that helps. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sat Sep 05 2009 7:50pm |
Hi there
Sun Oct 18 2009 8:58am |
think I found the problem
Sun Oct 18 2009 10:00am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
Mine has started to give low coolant messages again, keeping an eye on the levels and are ok, the message goes away after the engine warms up, and there is no mayo in the oil filler cap Phew! Sons of dogs come hither and get flesh
Mon Oct 19 2009 7:12am |
Mees, the bleed screw on mine has been leaking slightly, and I had a closer look at it yesterday, and it doesn't seem to have a seal on it at all, and the screw has a tang on the end of it to stop you taking it out of the coolant tank. I have put some PTFE tape (that plumbers use) on the thread of the screw and put it back in, and it seems to have stopped it weeping. I can't believe it has no seal, coolant will find it's way out of anything that has no seal or gasket unless it is absolutely precision manufacturing, (which LR's are most definately not ). RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Thu Oct 22 2009 9:11am |
Hi textar
Thu Oct 22 2009 1:16pm |
