![]() | Home > General > Door step tread plates |
awilde Member Since: 08 Jul 2009 Location: Oradea Posts: 16 ![]() ![]() ![]() |
I have exactly the same issue as this. |
mccalia1 Member Since: 09 Aug 2009 Location: UK Posts: 368 ![]() ![]() ![]() |
I'm struggling to understand...can you post a pic to explain? Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20" |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
I also have same issue but not had any joy with dealers wanting to replace it, if there is some documentation to cover the issue that would helpful. |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Open the drivers door and look down just inside the door seal - shiney metal plate...
My dealer caught his foot on mine and bent it up to a 45 degree angle! Going back this week to have it replaced - haven't seen a TSB on it but it would appear that the double sided tape/glue they use it just not up to the job. |
Aidan Member Since: 11 Sep 2009 Location: Irishland Posts: 92 ![]() ![]() ![]() |
Same problem here. It can't be that hard on diesel???
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 ![]() ![]() ![]() |
Haven't had this problem myself, but would have thought all bodyparts including interior fittings are covered by the Manufacturer's warranty for incorrect fitting.
Hmm, had a look through GTR and can't see a TSB about sill plates but that doesn't mean there isn't one. The site you mean is probably alldata.com but that is subscription access only.
Schmoogle, totally agree with you on how the Dealer would look at it.
