Home > Off Topic > Making speeding legal
Page 1 of 3 123>
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
In my Saab Aero Conv, i always was used to drive the speed displayed by my TOM TOM,
since this is much more accurate than the speedometer.
For example: max speed 120 km/h, i would maintain this speed as displayed on the TOM TOM,
with result that the speedometer indicated 128 km/h. This will give you an extra 8 km/h,
which saves you more than 1 hour on long trips for example from Amsterdam to Barcelona.
Of course, if you will add the legal required correction of 4 km/h (in case of a speeding ticket)
you can go as fast as 132 km/h (speedometer) legaly.
The question is: Is it possible to display the GPS speed on the RRS NAV display?
SW
Post #239770 Mon Oct 12 2009 11:25am
I may be wrong, but I wouldn't risk fine/points based on the perceived accuracy of a high street bought GPS sat nav system Confused Runner up - 2009 Best Avatar Award Sad
WINNER - 2008 �Best Thread� Award � Beautiful Women Of The World Very Happy
Runner Up - 2008�s Funniest Incident Sad
Post #239779 Mon Oct 12 2009 12:03pm
BKHK
Trots
Any sat nav will be more accurate then the speedo since it measures speed as a rate of change of position taking its information from your movement rather than from the vehicle's transmission. If you are at a stabilised speed, the sat nav should be very accurate once it has settled. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #239787 Mon Oct 12 2009 1:30pm
SkyWalker
The question is: Is it possible to display the GPS speed you on the RRS NAV display?
uhmmmm...so....is it?????????
(trust me, this calculation is watertight. And it is also confimed by the fact that Holland is equiped with radar detectors every 500 meters on the highway Wink .
Never had 1 ticket. Nil. Zero._
Post #239810 Mon Oct 12 2009 5:22pm
No, the RRS satnav does not have that ability.
Post #239854 Tue Oct 13 2009 8:13am
Josh
mmmm........interesting idea and a theory I've heard before.
But somehow you have to allow for the delay of the signal bouncing up to the satellite and back down again to your car. Occasionally blocked by an underpass or similar.
Personally I would stick to the reading the speedo gives you. Can't see any Court giving you leeway because your Tom Tom got it wrong. TDV6 - gone
TDV8 - gone
Post #239857 Tue Oct 13 2009 8:25am
BKHK
Josh
I can't see any leniency from courts either. In fact, here in Melbourne there is a speed camera that keeps detecting all offenders at the same elevated speed yet police say its accurate. Several have tried to use the GPS argument and failed.
However, in the absence of bridges etc, a sustained GPS reading will be more accurate than a speedo as it measures rate of change of position. In my field of aviation, GPS is extremely accurate in termsof its speed and position functions. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #239863 Tue Oct 13 2009 9:39am
SkyWalker
On long runs, you let the GPS settle down and stabilize the speed with the cruise control.
This way, any temporary obstruction of the GPS signal is of no influence.
And for the suspicious drivers, at the end, you still got the lagaly required correction (reduction) of 4 km/h in case of a,
unrealistic, speeding ticket.
The police is checking your speed with dopler radars, and each peace of this equipment has to be calibrated each year.
In case of a speeding ticket, it is standard procedure to request this calibration report from the police.
I don't understand that car manufacturers still use this very inacurate (upto 10% to high) and outdated method,
since there is already for many years more precise ways to measure distance traveled as function of time.
(thanks to the world of aviation and the military)
Post #239864 Tue Oct 13 2009 9:40am
SW, if it's that important to you then just get your TomTom and stick it in the car. Seems a lot of fuss about nothing though if you ask me Smile I also don't believe that any court would listen to you if you said your GPS told you the correct speed.... in fact, if I was the judge I'd throw the book at you for trying to be a smartarse Wink
Post #239871 Tue Oct 13 2009 10:25am
SkyWalker
Ok. If you prefer, i can stick to the ongoing discussions about collour coded mirrors, if that's more your cup of T... Whistle Wink
Post #239872 Tue Oct 13 2009 10:40am
Laughing @ Shmoogle Runner up - 2009 Best Avatar Award Sad
Post #239880 Tue Oct 13 2009 11:30am
Don't get me wrong, all discussion is good it just seems that you're labouring a bit of a moot point, that's all Very Happy
Post #239882 Tue Oct 13 2009 11:34am
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
To be fair to SW's original point, it's a well documented point that most cars speedometers are inacurrate by around 5%. Although I understood this can be both over and understating the speed.
I also use an additional gps device in conjuntion to the speedo, however I don't rely on either as Gospel. As I don't know exactly how accurate either are.
On UK roads volume of traffic dictates choice of speed most of the time, so you don't always get the opportunity to put SW's recomendation into practice anyway.
I prefer to use the saftey camera warnings to assist me, and road conditions in knowing when I can break the limit. And then I'm well over the limit by both the speedo and the GPS measurement. Obviously the safety camera datbase isn't entirely reliable, so I am still risking detection by plod.
Worth remembering that although many speed limits seem inappropriate in many locations. In many they are particurlarly valid.
Remember a Speed Limit is just that a Limit - Not a Target. Wink
Finally I'm pretty neutral on Mirror Colour Coding, Chrome or Original. Wink
Post #239890 Tue Oct 13 2009 11:53am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
GPS certainly isn't gospel.. think what happens when you go up (or down) a hill
speedos are surely overstating speed to cover manufacturers from being 'blamed' when drivers are caught speeding?
and as for the OP, i wouldn't assume that all authorities add on a blanket xx% in terms of mph.. the traffic taliban in North Wales for example are almost certainly an exception
if you are driving such a long route that 1 or 2 mph really matters then i would focus more on the route (and in particular the traffic) than anything else. And take your number plates off (or replace with fakes) so you can't get caught.
Post #239930 Tue Oct 13 2009 4:55pm
I agree rrsboy Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #239932 Tue Oct 13 2009 6:02pm
Page 1 of 3 123>
