Home > Technical > Is there any way to keep it in access mode?
Phil-r
United Kingdom 2008 Range Rover Sport TDV6 S Atacama Sand
Is there any way to keep the car in access mode? Confused
Cos it looks mint when dropped but looks a bit like its on roller skates in normal?
Post #239686 Sun Oct 11 2009 1:16pm
ELD70
No, at a certain speed it will always raise to normal height. Unless you pull out the compressor fuse and drive it with the car sat on the stops Shocked
Post #239687 Sun Oct 11 2009 1:30pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hi Ali - G
If you wanted a low rider, why you bought an all terain?
(there goes the neighbourhood...) Wink
SW
Post #239688 Sun Oct 11 2009 1:35pm
Phil-r
cos im 26 and i think im at the age where lower is better lol. ive got the scooby for fast b roads but i just think that on the 20"s the RRS looks a bit too high.
I have to get in too frames of mind, i sometimes am hurtling towards a corner and get to it and think.. Censored im not in the scooby. but the worst bit is going to esso and sticking the unleaded pump into the RRS.
Post #239691 Sun Oct 11 2009 1:51pm
http://www.matzker.de/product_info.php?products_id=739
Forgive Google translator but it was to much for me Wink
The Range Rover Sport has a Variable-height air suspension system with three positions. The lowest loading height is the height of the vehicle. It is designed for speeds up to 35 km / h.. At this height, the suspension has no suspension. The standard ride height is 50 mm higher. It is intended for road use in all speed ranges. In addition, there is the off-road ride height, which is 55 mm higher. During this suspension, the ride height has also a non-controllable reserve of another 70 mm, which only releases automatically when the vehicle is resting on the ground. With the Electronic Handling + offroad kit, we would like to use with this system is not fully exhausted possibilities of variable height air suspension. There is a Can Bus calculator, which can be the vehicle ride heights in the "Street" and "off" manually lowered by pressing a button or increased by 23 mm by 26 mm. In order to be elevated lowered the Range Rover Sport with an accessory both stra�enoptimiert as well as for off-road use. The application examples in detail: With the handling kit can be lowered, the Range Rover Sport in the standard ride height by 23 mm. This reduces the air resistance at motorway speeds and the driving stability is growing strongly. Even with faster travel on winding country roads, the less body roll and improved road holding an advantage. In the off-road vehicle ride height can be elevated for a further 26 mm. The advantage is clear, as with a ground clearance of approximately 275 mm (depending on tire size), the resting of the vehicle can be avoided, instead of releasing the reserve amount, only if the vehicle is already stuck. In Offroad-Tests haben wir festgestellt, dass es meist zu sp�t ist, die Aufh�ngung auszufahren, wenn das Fahrzeug bereits aufliegt. The suspension can then press into the soft ground and the car is secure. If, however, from the outset, the greater ground clearance is available, a deadlock can be avoided. The lowering in the street and raising the terrain are just the most common uses of electronic handling + offroad kit. An important application area is also driving on bad roads and paths. Here, the Range Rover Sport can be elevated in the road position. The ride will then increase dramatically, as more suspension travel is available. Silk absorbs the landing gear hard knocks. If the speed permanently over 100 km / h increases, is attributed to H�herlegung. This is another advantage, since the standard off-road height is only up to 50 km / h can be used. With the Electronic Handling + Offroad Kit is the variability of an air suspension system are so individually realized. Where once had springs and shock absorbers to be rebuilt, is now just press a button. Assembly 49 AW.
Post #239693 Sun Oct 11 2009 2:23pm
If you drive at anything resembling speed in access mode it will knock your fillings out and probably damage your RRS Runner up - 2009 Best Avatar Award Sad
WINNER - 2008 �Best Thread� Award � Beautiful Women Of The World Very Happy
Runner Up - 2008�s Funniest Incident Sad
Post #239694 Sun Oct 11 2009 2:26pm
Phil-r
fair point, it does feel a bit agricultural.
Post #239695 Sun Oct 11 2009 2:41pm
mccalia1
I know what you mean about Access mode as I agree it looks great when it's slammed to the deck but seriously, the ride is shocking Rolling Eyes
Check out AdamRRS, he has lowered his car 25mm above access height. Might be closer to what you're after?
http://www.rrsport.co.uk/forum/topic12521.html Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #239699 Sun Oct 11 2009 4:39pm
MAW
I think it looks too pimped in access mode Whistle Wink
It looks well as nature intended (as long as its on 19's or 20's) Laughing
Post #239700 Sun Oct 11 2009 5:10pm
mccalia1
Black RRS with Black tints, side steps and 20's looks pimped regardless of height! Thumbs Up Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #239704 Sun Oct 11 2009 5:25pm
MAW
IMHO lowered it then looks like a kerb crawler Laughing
Post #239722 Sun Oct 11 2009 9:20pm
