Home > General > Colour Coding - your thoughts please
Page 2 of 3 <123>
ROBO
United Kingdom 2009 Range Rover Sport TDV8 HST Alaska White
Door handles are big job.Just had mine done by the dealer says he will never do it again.New door handles are touch sensitive and they had to follow the wiring loom back to behind the dashboard to remove each one.Took 8 hours to take off and 8 to put back! Labour cost £100 an hour. Work that one out.I asked why they didnt just cut the wires and resolder and they said if there were any electrical problems the warranty would be void.
Mine is white so it had to be done may get a way with it in black. NEW RRS WHITE TDV8 1 OF 1
BYE BYE RRS TDV8 HST
WAITING FOR FERRARI CALAFORNIA
STILL GOT
FERRARI F430SPIDER
BENTLEY GT MULLINER
PORSCHE TURBO4
Post #238310 Mon Sep 28 2009 9:28am
That's a shame - they used to be a piece of pi** to do.
Post #238313 Mon Sep 28 2009 9:37am
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
I think colour coding in general looks better than not.
In certain colours and if too many parts are colour coded, I think the overall effect can be 'too plasticky' if you know what I mean.
Definately leave the roof pillars for the floating roof effect, and I'd probablyleave the rear scuff plate.
Some non colour coded parts can give a contrast effect to the main bodywork colour, standard cars have too much matt or grey parts.
Again some colours lend themselves to coding better than others.
But each to their own, life would be boring if we all liked the same things. Thumbs Up
Post #238315 Mon Sep 28 2009 9:56am
islider
ROBO,
that sounds like a nightmare job, and a bit of a pointless setup from LR's point of view.
What's the touch sensitive functionality, I take it that's why the handles wired to the loom?
Or is it a part of the alarm system, making the handles live. Wink
Would increase repair costs, if a new door was required, and it took an hour just to disconnect the handle never mind remove the door card, door seal, external trim and finally the door. Shocked
Post #238316 Mon Sep 28 2009 10:01am
It's the comfort access option - You get close with your key in your pocket and the doors unlock when you touch the underside of the handle...
Post #238318 Mon Sep 28 2009 10:16am
islider
Ahh, makes sense I suppose.
Sounds like a nice Premium feature, a good upgrade for the RRS.
But not sure I would spec that option, sounds like something to go wrong. I've had numerous electrical problems with mine, wouldn't want to create the potntial for more. I'd settle for unlocking with the key.
Post #238319 Mon Sep 28 2009 10:23am
If it's as reliable as the BMW version - steer well clear. And it's not so premium any more either - a mate's company Astra does the same thing, it even has a start/stop button! Rolling Eyes
Post #238322 Mon Sep 28 2009 10:29am
braddersmd
Hmm, it's very much looking like a stay clear on the handles then - even from a costing POV, let alone the potential for it to go wrong. Think I will see what the dealer says, and then take it from there - I'm waiting on the quote for the full lot.
Post #238323 Mon Sep 28 2009 10:56am
ROBO
Not sure if the handles are the same on all models.mine is TDV8 and I think its standard.May be TDV6 is option.So if you havent got the comfort access option no probs with colour coding.Have a look at the difference of colour coded or not on this link
http://s542.photobucket.com/albums/gg401/ROBRKW/ NEW RRS WHITE TDV8 1 OF 1
STILL GOT
FERRARI F430SPIDER
BENTLEY GT MULLINER
PORSCHE TURBO4
Post #238326 Mon Sep 28 2009 11:24am
Handles are the same per model, they only differ if you spec the comfort access - but from the outside they look the same.
Post #238327 Mon Sep 28 2009 11:28am
braddersmd
Comfort access - good question. I am assuming it has, it's the S/C I'm getting, and I don't recall being asked to tick this when I spec'd up originally - although I have taken one already in the system to get the 360deg cameras.
Will check up on this.
Cheers Bradders.
Post #238338 Mon Sep 28 2009 12:04pm
Standard on the HSE and above, so you will get it Bradders Thumbs Up
Post #238339 Mon Sep 28 2009 12:25pm
NickM
<======== Very Simple It Seems!!
I had my the pillars done, A, B and C.....the lower sills front and back, mirrors, handles, Sat Nav aerial, even the headlight washers at the front - only thing I should not have done is the steel trim on the running boards - still think the car is better colour coded Thumbs Up
Post #238340 Mon Sep 28 2009 12:28pm
braddersmd
Ta for the confirmation Shmoogle. Nice one.
You got a photo of yours NickM? - Care to share?
Post #238345 Mon Sep 28 2009 12:55pm
NickM
Mate PM your email...me is very thick and can't post pics on here..... Whistle
Post #238376 Mon Sep 28 2009 5:41pm
Page 2 of 3 <123>
