Home > Technical > Day Running Lights on 2010 model
Wall
United Kingdom 2009 Range Rover Sport TDV6 HSE Alaska White
Suposedly my new 2010 HSE has day running lights.
However they were not switched on when i purchased it.
The dealer has played around with the dealer settings and can only get front side,dip and rear on at once.
Any ideas?
Post #237319 Fri Sep 18 2009 3:02pm
Roland
Switzerland
I really do hope they can be deactivated by the dealer, should they be on as standard SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #237323 Fri Sep 18 2009 3:37pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
If its anything like the BMW crapdrive system, it will be a setting somewhere in the menus.
I think from conversations though (and very rarely I can be wrong) they are not driving lights (yet). They are purely side lights.................I could be wrong.
Good luck. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #237331 Fri Sep 18 2009 4:25pm
Josh
I think someone said recently that there will be a future software update to turn them on as day running lights in 2011/2012 ish when it becomes an EU legal requirement Question TDV6 - gone
TDV8 - gone
Post #237413 Sat Sep 19 2009 4:40pm
Lookers Park Royal
As I understand it, you can set DRL via the workshop PC (IDS) but it will be dipped beam, LED and rears. As Josh says, I'm also led to believe that when it becomes a legal requirement that there will be a new IDS setting for front LEDs only.
Sadly it's not configurable via the driver info module.
James Thumbs Up
Post #237423 Sat Sep 19 2009 7:20pm
SilverspeedRRS
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
It is a shame the LED front lights cannot be daytime running lights without the dipped beam! Is there no way the dealer cannot set just the fronts to come on at start up as they are pretty cool.
Post #238947 Sat Oct 03 2009 5:51pm
Bobby
Quote:
Daytime Running Lamps (DRL)
Daytime Running Lamps (DRL) use the full intensity low beam headlamps which are permanently illuminated when the vehicle is being driven. DRL are used in a number of markets and there are two systems to cover these markets.
DRL CANADIAN MARKET
DRL for this market use full intensity low beam headlamps. The side marker lamps, tail lamps and license plate lamps will be on, but instrument cluster illumination will be off. DRL are active when the following parameters are met:
*Parking brake is off on vehicles with manual transmission or PARK is not selected on vehicles with automatic
transmission
*Ignition switch is in the ignition position (II)
*The Central Junction Box (CJB) receives an engine running signal
*The lighting control switch is in the off or side lamps position.
NOTE:
If the lighting control switch is moved to the headlamp position, DRL are deactivated and normal side lamp and
headlamp functionality is operational.
NOTE:
Adaptive Front lighting System (AFS) (where fitted) is non-functional when the DRL are active.
NOTE:
When DRL are active, the headlamp flash function using the left hand steering column multifunction switch will operate normally. The high beam headlamp function using the left hand steering column stalk switch will be deactivated.
When the parking brake is applied on manual transmission vehicles or the selector lever is in the PARK position on automatic transmission vehicles, DRL are turned off. This is to reduce battery discharge during long periods of engine idling in cold climate conditions. When the parking brake is released or the selector lever is moved from the PARK position, normal DRL functionality is restored.
DRL DENMARK, HOLLAND, NORWAY, SWEDEN, FINLAND & POLAND
DRL for these markets use full intensity low beam headlamps. Side lamps and license plate lamps will be on, but instrument cluster illumination will be off. DRL are active when the following parameters are met:
*The CJB receives an engine running signal
*The lighting control switch is in the off position.
NOTE:
If the lighting control switch is moved to the side lamp or headlamp positions, DRL are deactivated and normal side lamp and headlamp functionality is operational.
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #238997 Sun Oct 04 2009 11:54am
Somebody's out to retain their Tech-head title for another year... Whistle Wink Runner up - 2009 Best Avatar Award Sad
WINNER - 2008 �Best Thread� Award � Beautiful Women Of The World Very Happy
Runner Up - 2008�s Funniest Incident Sad
Post #239002 Sun Oct 04 2009 1:21pm
Bobby
Smile Malaysia Boleh!
Post #239003 Sun Oct 04 2009 1:34pm
AlanT
Bosnia Herzegovina
Just switched DRL two days ago. There are three options: Canadian, Scandinavian and Poland DRL. Since it is a legal requirement in Bosnia to have dipped beam on at all times, went for Scandinavian option. Agree with SilverspeedRRS, LED should be daytime lights only. RRS TdV6 MY2010
Santorini Black
Post #239067 Mon Oct 05 2009 11:12am
