Home > General > Return of the Craptenintal Tyres
wokkaman
United Kingdom 2013 Range Rover Sport Supercharged HSE Zermatt Silver
Had a look at an HSE 2010my (so I could show Mrs Wokka the Extended Leather Pack) and noticed it had Conti's on it and not Pirellis Evil or Very Mad cant believe after all the moans about them they have gone back to them!!
Can you specify?? One for James at CHPR? GONE** RRS 3.0SC Silver fully loaded Smile - 2020 110 loving it
BMW R1200GSA Rallye
GONE** Fiesta ST2 - Mrs Wokka's - AMG35 now
GONE**BMW K1600GTLE Matt Blue
GONE**Disco 4 2014 Firenze Red
GONE**Evoque SD4 Dynamic Coupe
GONE**RRS 5.0 SC
GONE**RRS HSE TDV8
GONE**RRS HSE TDV8 (The Crap one)
GONE**FL Facelift
GONE**FL 1
GONE**D1
GONE**BMW R1200GS Adventure
GONE: Kawasaki ZX10R
GONE: Focus ST2
** Chinook CH47 - 2 x T55 engines 3,750 hp each!! 183mph, 2xM134 Miniguns, 1xM60
Post #236593 Mon Sep 14 2009 11:48am
TonyR
is that the Continental Sport Contact that is rubbish? They dont seem to be that badly rated online at a few sites (though that doesnt mean too much).
Is the preferred type the Pirelli Scorpion Zero?
Post #236597 Mon Sep 14 2009 12:25pm
Lookers Park Royal
Woka,
In a nutshell...... No! However.......................... If the supplying dealer has a stock vehicle with your preferred choice at the time of handover then I'm sure a swap could be arranged for a nominal fee (i.e. cost of swapping 8 tryes round).
I'm under the impression that rather than have all eggs in one basket, they will use a few different suppliers, that said, our showroom car and demo both have Conti's.
One to discuss nearer the time I think.
James Thumbs Up
Post #236599 Mon Sep 14 2009 12:49pm
wokkaman
8k and the wear was terrible.... LR quoted "its not a sports car and I must driving it round roundabouts to hard" Blow me thought it said "SPORT" on the back of the car and it was all four tyres, I stated I was not in the habit of going the wrong way at roundabouts!! By 12k on the inside tread the braid was coming through... done 22k on the Pirrellis with out issue
Charles Hurst Park Royal wrote:
Woka,
James Thumbs Up
Cool - Guess I will be doing a deal with you James Bow down GONE** RRS 3.0SC Silver fully loaded Smile - 2020 110 loving it
BMW R1200GSA Rallye
GONE**RRS 5.0 SC
GONE**RRS HSE TDV8
GONE**FL Facelift
GONE**FL 1
GONE**D1
GONE: Focus ST2
Post #236604 Mon Sep 14 2009 1:04pm
TonyR
used to fitting Goodyear F1s on previous sports cars - so 8k wear rate is higher than usual for me Smile
Post #236606 Mon Sep 14 2009 1:11pm
I would have thought the soft compound of the Conti would give good grip for the S/C and probably the TDV8's torque too. Probably less of an issue on the TDV6 Question
Just a thought... Runner up - 2009 Best Avatar Award Sad
Post #236641 Mon Sep 14 2009 6:22pm
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
The Continentals are fitted on the XC90s as standard and the wear there on 18" rims is atrocious. As Wokka says 6-8k and theyre having to be changed yet they persist with them. There are endless threads about it over there with the 4 wheel alignment having to be done every 6 months to try drag a bit more miles out of them. Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #236734 Tue Sep 15 2009 10:34am
Part of the problem I see is that from new, the shoulders of the tyre already have much reduced tread compared to rest of the tyre.
Continental claim this is to increase treadblock stability on a 2.7tonne 4x4.
In reality this leads to premature tyre wear on both shoulders of each tyre (In my opinion) Runner up - 2009 Best Avatar Award Sad
Post #236776 Tue Sep 15 2009 1:10pm
Part of the problem is that many people don't keep an eye on the pressure of their tyres and so tend to get uneven and increased wear. 2005 Zambezi TDV6 - Gone but not forgotten
Post #236780 Tue Sep 15 2009 1:12pm
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Fair point on tyre pressures VA.
Although since having mine on for 16 months and about 8k, the shoulders are well and truly shot.
And due to my car suffering from the steering shimmy issue, my car had the four wheel alignment, RFV wheel balancing and I monitored the pressures and tread depths fairly regularly. To no avail. Big Cry
Only other thing I can think of is hard cornering, this will generally lead to outer tread wear. And I have chucked mine about a fair bit. Whistle
Post #236795 Tue Sep 15 2009 1:41pm
flydive
O my TDV8 I usually keep my Contis pressure a bit higher than recommended, to avoid the "feature" I experinced on TDV6. So far 13000 Km and shoulders still look ok '08 RRS TDV8
Post #236805 Tue Sep 15 2009 1:58pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Also keep mine a bit higher than normal too and the wear pattern looks ok so far.
At least they last a bit longer than the rear tyres on my MG where I'm luck to get 5k miles out of them ... and that was before I put the supercharger on the car Twisted Evil Sons of dogs come hither and get flesh
Clan Cameron
Post #236825 Tue Sep 15 2009 3:38pm
Josh
So Flydrive and Alicatt,
What tyre pressures are you running on to improve the shoulder wear Question
I've been running the last two sets at F 33 R 36 psi as per the figures recommended by LR and I get premature outer shoulder wear PDQ Exclamation I also check the pressures weekly Exclamation
Having just put a set of tyres on I'm willing to try a bit more air. Generally only me in the car and occasionally my wife.
James,
Have you any thoughts/advice on this Question TDV6 - gone
TDV8 - gone
Post #236837 Tue Sep 15 2009 5:22pm
Gazzer
That's not good to hear. I have Goodyear Wranglers on my Disco3. 20k miles and not a scrap of wear seeing as I don't treat it like a 2.7t barge! So tye Pirellis are best? Will check out which ones I have. I personally don't expect to change gyres on a car sub 30k miles/3 yrs which is the shelf life of a car fir me. So I wouldn't be happy spending cash on gyres after less than a year. Anyone got a link to a related old thread? 2010MY Land Rover Freelander 2 HSE
Santorini Black with Ebony Napoli Leather
Post #236838 Tue Sep 15 2009 5:23pm
Alicatt
38psi Front and 40psi Rear Sons of dogs come hither and get flesh
Clan Cameron
Post #236855 Tue Sep 15 2009 8:32pm
