Home > Technical > Drivers Door Locking Problem. |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 |
what years yours aiden..? i had same problem with mine & was fixed under warranty & if i remember it was solenoid that had gone.
Fri Sep 11 2009 9:22am |
Yep, this is quite a common issue... if under warranty, simple to get fixed
Fri Sep 11 2009 9:26am |
Aidan Member Since: 11 Sep 2009 Location: Irishland Posts: 92 |
Feb 06 It can't be that hard on diesel???
Fri Sep 11 2009 9:31am |
OK, cheaper to find an LR indy then... he'll know what he's doing with the product (hopefully) but won't cost you £120/hr in labour
Fri Sep 11 2009 9:38am |
I can probably get a damaged door from breakers real cheap, use the good parts from the inside. Whats an "indy" though? It can't be that hard on diesel???
Fri Sep 11 2009 9:40am |
An independent LR specialist - worth using them after warranty has expired, as they are much cheaper especially when larger pieces of work are required where main dealer rates would make things very expensive.
Fri Sep 11 2009 9:44am |
just been oh this site & found this it might be usefull.
Fri Sep 11 2009 9:46am |
No chance it could be DIY? Or call in a favour from just a friendly grease monkey? It can't be that hard on diesel???
Fri Sep 11 2009 9:49am |
ive just googled (rangerover spares) & theirs a few breakers breaking rrs.i would'nt think it was a hard diy job. |
Fri Sep 11 2009 9:53am |
I'm the least mechanically minded person here, so it could be easy enough for someone who knows what their doing I suppose - not sure
I used to be pretty good at Lego
Fri Sep 11 2009 9:57am |
redrangey Member Since: 28 Nov 2009 Location: sheffield Posts: 5 |
had the same problem on drivers door and yes when you tke the door card off you cant get to the mechanism
Sat Nov 28 2009 11:27am |
