![]() | Home > Technical > Drivers Door Locking Problem. |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 ![]() ![]() ![]() |
what years yours aiden..? i had same problem with mine & was fixed under warranty & if i remember it was solenoid that had gone.
Yep, this is quite a common issue... if under warranty, simple to get fixed |
Aidan Member Since: 11 Sep 2009 Location: Irishland Posts: 92 ![]() ![]() ![]() |
Feb 06 |
OK, cheaper to find an LR indy then... he'll know what he's doing with the product (hopefully) but won't cost you £120/hr in labour |
I can probably get a damaged door from breakers real cheap, use the good parts from the inside. Whats an "indy" though? It can't be that hard on diesel???
An independent LR specialist - worth using them after warranty has expired, as they are much cheaper especially when larger pieces of work are required where main dealer rates would make things very expensive. |
just been oh this site & found this it might be usefull.
No chance it could be DIY? Or call in a favour from just a friendly grease monkey? It can't be that hard on diesel???
ive just googled (rangerover spares) & theirs a few breakers breaking rrs.i would'nt think it was a hard diy job. |
I'm the least mechanically minded person here, so it could be easy enough for someone who knows what their doing I suppose - not sure |
I used to be pretty good at Lego |
redrangey Member Since: 28 Nov 2009 Location: sheffield Posts: 5 ![]() ![]() ![]() |
had the same problem on drivers door and yes when you tke the door card off you cant get to the mechanism
