Home > General > Range Rover V6 v Jaguar V6 |
TonyR Member Since: 04 Sep 2009 Location: Sussex Posts: 48 |
From what I understand the engines for Range Rover and Jaguar are effectively the same
Mon Sep 07 2009 1:04pm |
Yep, physically the same engine but different maps for different uses
Mon Sep 07 2009 2:40pm |
Alias Member Since: 18 Aug 2009 Location: Zürich Posts: 194 |
The RRS has a different AWD. A RRS need power for AWD the Jaguar need power for speed and acceleration. |
Mon Sep 07 2009 2:49pm |
Jaguar is RWD not AWD! Xtype had 4WD but not XF 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Sep 07 2009 3:47pm |
Gazzer Member Since: 21 Oct 2005 Location: Salisbury Plain Posts: 318 |
The new ediff on the XFR and XKR is taken from the Disco/RRS.... 2010MY Land Rover Freelander 2 HSE
Mon Sep 07 2009 8:33pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
I believe the RRS engine is based on the high output TDV6 lump but as Tim said, retuned for the needs of a 2.7 tonne 4x4. I think the RRS has more torque than the XF. Runner up - 2009 Best Avatar Award
Tue Sep 08 2009 5:40am |
It is also engineered to be able to operate at strange angles that Land Rovers are able to get to that Jaguars couldn't even dream about getting to, and still be able to normally lubricate the oily bits at these silly angles. IIRC ALL Land Rovers engines are engineered to stay running at 48 or 50 degrees across a slope and up and down a slope - apparrently no other SUV can operate at angles more than 40degrees. Standrad max imum is a 45degree cross slope and you don't want to go there intentionally in 2.7tonnes of luxury car, and if you do you are recommended to put the suspension into access mode to lower the centre of gravity of the car and to remove anything you have on the roofrack! I also believe the air intakes on the LR version are different and the new TDv6 will look cool in G4 guise as it has an intake for each bank of the V so that means either a raised intake on each wing or a very complex sealed breathing system to one raised intake! There are no dummy intakes on the 3.0ltr TDv6 like the 2.7 has 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Sep 08 2009 8:47am |
think i will leave as standard then.
Wed Sep 09 2009 7:29am |
