Home > General > Rattle?
Big D
Scotland 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Rattle?
Has anyone else experienced this? Have noticed a slight rattling (sounds kinda like a dry gearbox?) when lifting of the accelerator under load, usually lower down the gears only lasts a second or so. Can sometimes hear the noise when coasting, when im just lightly pressed down on the accelerator pedal. Asked dealer to check when it was in for 4th service, but they said no issues??
Post #229647 Sat Jul 04 2009 12:56pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Could be the rattle I have... sounds like similar circumstances although mine is clearly coming from somewhere in front of the driver, so I don't think its the gearbox..
My RRS has been in about 6 times with it and the dealer had to place small microphones into different areas to locate it. Current hypothesis is that it is something to do with a bracket or collar from the steering rack. Ther part is on back order and I'll report when it is eventually replaced.
The dealer is also hoping that this part will fix the RRS's other current problem of pulling to the left!
Post #229666 Sun Jul 05 2009 7:16am
Big D
Hope that you get a result when the parts fitted. thanks for replying, give me a shout and let me know if it does the trick!
Post #229714 Sun Jul 05 2009 10:36pm
2nd Rower
Booked in for next Tuesday - apparently they are going to replace the steering rack!
Post #229868 Tue Jul 07 2009 2:19am
Big D
More I think about it, not sure if its the same thing. Mine comes on, and has similar sound, as a dump valve, when I lift of accelarator (only more metallic)? Does it sound the same as yours 2ndRower?
Post #230115 Wed Jul 08 2009 10:16pm
2nd Rower
Not sure what a dump valve sounds like. Mine always soundded like it was coming from something to do with the the steering / wheels.
Post #230132 Thu Jul 09 2009 1:26am
2nd Rower
I got this wrong - They replaced the steering column last week, but this hasn't fixed the issue, so they are now going to replace the steering rack next week!!
Post #231493 Wed Jul 22 2009 5:10am
Big D
I will keep an eye on this then Rower, i've hit a blank everywhere else Big Cry
Post #231556 Wed Jul 22 2009 3:23pm
2nd Rower
They replaced the steering rack a week or so ago to no avail, and having replaced pretty much every component around the steering the dealer called in Land Rover Australia.
I took the LRA rep for a test drive on friday and the 'rattle' issue immediately occured at ~60km/h as it had always been doing. He commented that "hadn't heard this noise before" and "if this was my car then it would annoy the hell out of me" Evil or Very Mad
He has authorised for the dealer to pull out the entire dashboard... Not sure what they are looking for, but he is confident this is where the "rattle" is coming from... Apparently it's a big job so will be in for 3 days towards the end of the month..
Must say I'm looking forward to a poxy Volvo loan car Whistle
Post #233623 Sun Aug 16 2009 4:18am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
UPDATED Monday
good luck 2nd, hope you get it back with less rattles.. Mines in tomorrow for the quarterly lets hunt the radio problem,
I have an annoying rattle that is becoming from behind the sunroof, if you push the roof lining up it stops, its taken 3 weeks and a lot of swearing to find it, current fix is a folded piece of cardboard shoved between the Sunroof internal sliding cover and the roof liner Laughing
The list when it went in today:
Brake Recall
Fuel Injector/pump/whatever Recall ?
Rattle in roof lining (behind sunroof)
Suspect Front Ball joints problem, have these been redesigned Question
Radio problem treasure hunt (cabin being stripped out)
They reckon they can crack it in 2 days Shocked Not a Volvo, Corolla or A3 in sight, the loaner is
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #233632 Sun Aug 16 2009 11:34am
FieryJack
Ireland 2005 Range Rover Sport TDV6 SE Cairns Blue
Just wondering, did they fix the 'rattle' from the sunroof? it's just a blue oil burner
Post #235727 Sat Sep 05 2009 10:29am
2nd Rower
Re: UPDATED Monday
They had it for three days and the MLR mechanics, having driven around with the dashboard out of the car, claim the problem was with the 'crank angle sensor' and they are waiting for a new one to come from the UK.. In the meantime they've done a 'modification'... I think they are just guessing as the niose still happens now and again, although a lot less, but there is still a horrible reverboration you can sense in the steering wheel at ~60km/h
Oh and the car still pulls to the right..
So despite reporting all these problems back in Feb, and the car going in 2 to 3 times a month since then i'm still driving around in a 'defective' car. I'm now getting past this, after more than 6 months with these problems and am likely to escalate now... My good will and patience has been used up.. Evil or Very Mad Censored
Volvo was poxy and not really a fair substitute for the RRS for 3 days..
Post #235790 Sun Sep 06 2009 10:34am
