Home > Off Topic > WD40 - an interesting programme
Tim in Scotland
On R4 this evening is a very interesting programme about WD40 and how it started out as a water dispersant for the space industry.......................... the most successful recipe was No40, hence the name Water Dispersant 40!
You can download it as a podcast to itune here http://www.bbc.co.uk/podcasts/series/worldbiz They even have to add the unique "smell" to it as it doesn't have a natural smell! Eau de WD40..............................
Among the more unusual uses :-
It is used to stop swallows building nests on buildings as the mud they make their nests from will not stick to any surface sprayed with it.
Or for stopping squirrels from raiding your garden bird-feeders because they cannot grip the pole once you have sprayed it with WD. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #234917 Thu Aug 27 2009 7:47pm
flydive
Official 2000+ uses list
http://www.wd40.com/files/pdf/wd-40_2042538679.pdf '08 RRS TDV8
Post #234918 Thu Aug 27 2009 8:04pm
Tim in Scotland
Shocked
>Lubricates gun table rollers
• Lubricates track adjusting screws
• Lubricates tank ignition system
• Lubricates precision gun fittings
• Removes stubborn stuck-on leg wax Laughing 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #234955 Fri Aug 28 2009 6:13am
Cleans peanut butter from shoestrings!
You have to ask... why? Shocked
Post #234956 Fri Aug 28 2009 6:48am
Maybe when your using the peanut butter to clean your black plastic car bumper you spill some on your shoes Laughing
Post #234961 Fri Aug 28 2009 7:12am
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Best use I had for it, other than water dispersing, was spraying everything under the bonnet on my first cars. Rocker cover, distributor cap, HT leads, air filter, radiator, anything under there.
It dried (still sticky) to a nice shiny finish, probably clogged up the air filter though Laughing
Post #234967 Fri Aug 28 2009 7:37am
