![]() | Home > Technical > lazy entry |
2009 rover Member Since: 10 Aug 2009 Location: germany Posts: 15 ![]() ![]() |
hello new hear can someone tell me what lazy entry is its no where in my manual |
Welcome 2009 Rover |
Jonty Member Since: 11 Mar 2008 Location: Sat with my head in my hands wondering what the hell I'm doing Posts: 508 ![]() ![]() |
doesn't it also move the seats all the way back when leaving the vehicle |
Yep, supposedly... |
merwiz Member Since: 26 May 2009 Location: Wirral Posts: 143 ![]() ![]() ![]() |
I've never had my seat move back, and the mirrors sometimes refuse to return the the standard 'up' position after they have tilted 'down' to reverse.
awilde Member Since: 08 Jul 2009 Location: Oradea Posts: 16 ![]() ![]() ![]() |
I have the same issues with the mirrors not returning, This only happens occasionally. If lazy entry is related to the seat position with diffrent keys how do you program the seat position to the key? |
Go through the process with your chosen key in the ignition... the settings get written to it, so that when you insert the key next time it reads and sets them. It's all fairly pointless if you're the only one who ever drives it.
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
it applies the settings when you use the unlock button. The wife has one setting and I another just got to remember not to pick up the wrong key.
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
AFAIK that's not part of Lazy Entry. I think the seat slides back and the steering column lifts up and away from you when you remove the key from the ignition only if you have the electrically adjustable steering column and flip that switch to Auto. The memory mirrors can be trouble if you have a 2006/7 and have Lazy Entry enabled. A bunch of memory modules were defective and caused the mirrors to go nuts, there was a TSB issued last year or so. I just turned Lazy Entry off, like others have said it is a useless feature if you are the only driver and/or only use one key to open the car. ![]() |
