![]() | Home > Off Topic > Anybody watching the meteor showers tonight? |
Tonight the earth passes through a "cloud" of space dust and mini meteors called the Perseid Showers - should be visible anywhere in the world tonight. So long as you are away from streetlights and have a clear sky you should see several meteors a minute passing through the heavens
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Unfortunately only the Scots will get a view of it |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
all cloud here - annoyingly last night the sky was completely clear here and apparently it started last night - however we didn't realise |
We have a very thin layer of high cirrus clouds here tonight but twilight is only just turning to full night so sky is quite light still. All I have seen are lots of bats out hunting so far...................... ! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wozz Member Since: 28 Dec 2008 Location: Cheshire, United Kingdom Posts: 826 ![]() |
You should be seeing it by now Tim. It actually started back in July but today is the zenith. It will still be viewable over the next week or so but with a lower ZHR (zenithal hourly rate). The ZHR tonight should be about 100 so plenty to see - if you have no cloud spoiling the view..
Still too light here can just see a planet (don't have a current almanac at home to see which one it is but I suspect it is Jupiter) in the south about 10 degrees elevation 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Aye thats Jupiter. You may also be able to see Neptune just to the left (East) and up by about 2 degree's if you have a decent pair of bins. If you look directly up you may also be able to see a bright star right above your head. thats Vega. You can track the "summer triangle" asterism left from Vega to the star Deneb and then south west to the star nearer the horizon called altair.
Wozz, the only stars I know these days are in the constellation of GPS! Haven't picked up a sextant in decades. The only thing we use the stars for now is checking the compasses but I do have lots of experience of sextant navigation and using sun and stars to position fix. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Hah - a little like me and map reading. Oh I love the nanny state and all its trinkets!
I'm using my Steiner Navigator 7x50 bins - what is the scintelating red/white/ green body in the NE at about 12 degrees (it isn't a plane as it is not changing bearing or elevation. Have seen a few meteors, and about 5 years ago at this time of year I remember seeing these showers during the day! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
There are a few messiers around that area but I am not sure which one it is. You have M13 just to the south and east of the perseids.
Looks like its probably the M34 Nebula which is more ENE.
I'm out in the countryside but there are enough street lights to be annoying but worse are my neighbours security lights! Just been outside for 10 minutes and obviously this has been on the evening news as several were out in the courtyard trying to spot them................................... they were most impressed that I could identify so many stars / planets and the messiers! |
Damn - I need to sneak on board one of your ships with my bins and a butty box.
