![]() | Home > General > Nitrogen Tyre Inflation |
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
?? Read a bit about this, some good, some saying load of waffle?? Going to get 2 new front tyres Wednesday and they offer it, any thoughts/comments GONE** RRS 3.0SC Silver fully loaded |
Hmm, they fill aircraft tyres with nitrogen. The idea being it behaves differently from air at a particular pressure, leading to less wear, therefore perceived to be safer.
we have them in the tyres, but alot of car tyre companies are offering them now. GONE** RRS 3.0SC Silver fully loaded ![]() BMW R1200GSA Rallye GONE** Fiesta ST2 - Mrs Wokka's - AMG35 now GONE**BMW K1600GTLE Matt Blue GONE**Disco 4 2014 Firenze Red GONE**Evoque SD4 Dynamic Coupe GONE**RRS 5.0 SC GONE**RRS HSE TDV8 GONE**RRS HSE TDV8 (The Crap one) GONE**FL Facelift GONE**FL 1 GONE**D1 GONE**BMW R1200GS Adventure GONE: Kawasaki ZX10R GONE: Focus ST2 ** Chinook CH47 - 2 x T55 engines 3,750 hp each!! 183mph, 2xM134 Miniguns, 1xM60 |
awilde Member Since: 08 Jul 2009 Location: Oradea Posts: 16 ![]() ![]() ![]() |
I have nitrigen in the other car (old golf) and what I can report is a more constant tire pressue independant of the tire temperature and that you are less likely to need to top up the pressure.
cheers |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
![]() ![]() ![]() Nitrogen has larger molecules than oxygen yes..... but that wouldn't reduce seepage ![]() Anyway most people fill their tyres with air (not oxygen) which is 78% nitrogen anyway! |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I have a mind full of useless info that i have read ![]() shame i don't keep hold of the useful stuff too ![]() anyway i knew i had read it once upon a time ![]() |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 ![]() ![]() ![]() |
I used this in my XK8 tyres. it totally changed the handling of the car as it firmed up the side walls and made the ride a little stiffer.
fairpoint NP, you are not to blame, the fool that wrote it is.....i'm sure everyone appreciates how small a molecule is (nitrogen or otherwise) and that is utter rubbish! |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Seems like a pain to me.....there you are doing your weekly checks and you find you need a bit of air in your tyres out comes the trusty foot pump and jobs a good one.
It does seam a little far fetched when it gets down to molecular structures of the tyres JF |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
i would happily wager a not insignificant amount of cash that presented with two identical cars (other than what the tyres were filled with) you could not (10 times out of 10) tell the difference between the two not least because air = 80% nitrogen (no offence intended... its just i put this gimmick in the same box as windscreen wiper spoilers) |
RANGE_LOVER Member Since: 01 Jun 2009 Location: London Posts: 306 ![]() ![]() ![]() |
aahaaa, But what about helium???? |
Wont be as bad as you think in a LR.....17 to 19 in say a BMW is a huge difference.....on 19s in a beemer if you hit a pothole its like crashing! 19s in a LR will still be smooooooooooth and look ![]() |
