![]() | Home > General > stereo fault |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
If the car is under 3 yrs old take it to the dealer and get it fixed/parts replaced under warranty. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
vougese39 Member Since: 21 Jul 2009 Location: leicestershire Posts: 4 ![]() ![]() |
the vehicle is a late 55 reg but is 06 spec model nolonger under warranty |
Ah, in that case try taking it to a specialist car audio repair/installer as this sounds like a bad connection which then heats up in the 30 sec to 2 min time span and trips the unit. If you state your approximate location someone on here may recommend somewhere local to you.
found the fault it is a software issue |
Vougese - would you put a post saying what the symptons were and how it was cured - it might help somebody else 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
