Home > General > stereo fault
vougese39
stereo fault
i have a range rover sport 06 modelwhich has no faults but when you start the car and switch the stereo on the nav and stereo works all ok but after 30sec to 2 min then the stereo switchs off and so does the sat nav display if you switch off and restart all is ok till 30 sec to 2 min then it goes off again have tried switching the stereo on to no avail all ideas greatly recived stu
Post #231453 Tue Jul 21 2009 5:39pm
rrsjo
If the car is under 3 yrs old take it to the dealer and get it fixed/parts replaced under warranty. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #231456 Tue Jul 21 2009 5:49pm
vougese39
the vehicle is a late 55 reg but is 06 spec model nolonger under warranty
Post #231459 Tue Jul 21 2009 5:55pm
rrsjo
Ah, in that case try taking it to a specialist car audio repair/installer as this sounds like a bad connection which then heats up in the 30 sec to 2 min time span and trips the unit. If you state your approximate location someone on here may recommend somewhere local to you.
Hope this helps. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #231480 Tue Jul 21 2009 10:23pm
vougese39
found the fault it is a software issue
Post #231791 Fri Jul 24 2009 7:49pm
Tim in Scotland
Vougese - would you put a post saying what the symptons were and how it was cured - it might help somebody else 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231814 Sat Jul 25 2009 8:20am
