Home > Maintenance & Modifications > Brake sensors - change or not ????
moakley
England 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Question Quick question. I'm going to change my rear brake pads.
If the sensor warning has NOT come on yet - is the sensor reusable?
I ask as many people sem to suggest changing the pad easy but the sensor a bit of a sod - so if I can avoid it I will
Any thoughts please?
Post #231602 Wed Jul 22 2009 8:36pm
MAW
Yes - if your sensor is not decalring yet then you are OK - if it was you would not know if it was the front or rear declaring without a visual....
Post #231607 Wed Jul 22 2009 9:51pm
NickM
I maintain that the sensors don't work - I got told my pads were at 92% and 95% - and yes they still 'lipped' the discs - and no sensors told me I had so little time left - apparently the sensors are embedded quite deep into the pads, I'm not sure they would even tell you before it was too late.....I think the sensor part is a waste IMHO
Post #231621 Thu Jul 23 2009 7:12am
MAW
I have had scare tactics from Dealer in the past Nick. The sensor is seperate from the pad but mounted along side... IME when it starts alerting you have around 3mm+ of pad left and IIRC they are about 12-15mm deep when new. I did possibly 500 miles after the sensors started telling me it was time....
Some dealers will tell you time is up just for the exchange and £, IME the sensors worked and did there job twice on my last RRS....
92% is an interesting figure to be quoted..... assuming sensors were fitted (and i think if they weren't the sensor lamp would be on anyway) , you had plenty of time Laughing
Post #231623 Thu Jul 23 2009 7:31am
