![]() | Home > Maintenance & Modifications > Brake sensors - change or not ???? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Yes - if your sensor is not decalring yet then you are OK - if it was you would not know if it was the front or rear declaring without a visual.... |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
I maintain that the sensors don't work - I got told my pads were at 92% and 95% - and yes they still 'lipped' the discs - and no sensors told me I had so little time left - apparently the sensors are embedded quite deep into the pads, I'm not sure they would even tell you before it was too late.....I think the sensor part is a waste IMHO |
I have had scare tactics from Dealer in the past Nick. The sensor is seperate from the pad but mounted along side... IME when it starts alerting you have around 3mm+ of pad left and IIRC they are about 12-15mm deep when new. I did possibly 500 miles after the sensors started telling me it was time....
