Home > Technical > Anti-roll bar active control module
dcc
Guernsey 2008 Range Rover Sport TDV8 HSE Java Black
I have the RRS TDV8. I have discovered that the anti-roll bar active control module is leaking oil. Is anyone familiar with this problem? Is it common? Is it serious? I want to go greenlaning next week. Should I postpone the trip until the leak is repaired? As the vehicle is less than 2 years old would this be a warranty repair?
Sorru for so many questions.
Post #227688 Tue Jun 09 2009 6:15pm
Not something I've heard of, but would definitely be warrantied. Best get along to your dealer Thumbs Up
Post #227707 Wed Jun 10 2009 7:48am
Bobby
I'm not sure what 'anti-roll bar active control module' you're talking about. If you mean the Dynamic Response control module then that's way up high behind the instrument panel and there's no oil in it.
Most probably its oil leaking from the actuator at the stabilizer bar or from the fluid pipe connections. Other than the high pressure pipes, oil can also leak from the pump or valve block. This is serious.
Anyway, its advisable to get the vehicle checked by your dealer as soon as possible since prolonged driving with less or no oil is going to cost you in the long run. Surely a vehicle less than 2 years old is covered under warranty, no? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #227811 Thu Jun 11 2009 3:04am
dcc
Thank you shmoogle and Bobby for your interest.
I am waiting to hear from the dealer about a replacement part.
I should mention that this module is at the rear.
I have no personal knowledge about it. I am having to rely on the mechanic who discovered it.
Post #227816 Thu Jun 11 2009 5:47am
Bobby
It might be the rear stabilizer bar actuator then. Wink Malaysia Boleh!
Post #227823 Thu Jun 11 2009 7:10am
hi Bobby btw Smile long time Smile
Post #227830 Thu Jun 11 2009 7:24am
rrsjo
If you mean the big lump in the centre of the roll bar at the rear (and at the front) then yes I had mine leak. New seals fitted first but it still leaked, so new unit fitted. All covered by 3 year warranty. If the oil in the DR reservoir has not dropped much it will be OK to use on the road. It should make no difference when off roading. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #227841 Thu Jun 11 2009 8:38am
Bobby
Hi Angel,
Not so long but not so many posts recently! Laughing Malaysia Boleh!
Post #227842 Thu Jun 11 2009 8:41am
dcc
Thank you all for your input.
I have no technical knowledge but the dealer says it is the module that regulates the vehicle when it rolls left or right.
They accept it is a warranty claim and will replace it tomorrow or early next week.
So far so good.
Again, thanks.
Post #227857 Thu Jun 11 2009 9:12am
Bobby
Good to hear about the warranty claim and hope all goes well for you. Thumbs Up Malaysia Boleh!
Post #227870 Thu Jun 11 2009 9:48am
