Home > Technical > Anti-roll bar active control module |
dcc Member Since: 23 Jun 2008 Location: Channel Islands Posts: 32 |
I have the RRS TDV8. I have discovered that the anti-roll bar active control module is leaking oil. Is anyone familiar with this problem? Is it common? Is it serious? I want to go greenlaning next week. Should I postpone the trip until the leak is repaired? As the vehicle is less than 2 years old would this be a warranty repair?
Tue Jun 09 2009 6:15pm |
Not something I've heard of, but would definitely be warrantied. Best get along to your dealer
Wed Jun 10 2009 7:48am |
Thank you shmoogle and Bobby for your interest.
Thu Jun 11 2009 5:47am |
It might be the rear stabilizer bar actuator then. Malaysia Boleh!
Thu Jun 11 2009 7:10am |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
hi Bobby btw long time
Thu Jun 11 2009 7:24am |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
If you mean the big lump in the centre of the roll bar at the rear (and at the front) then yes I had mine leak. New seals fitted first but it still leaked, so new unit fitted. All covered by 3 year warranty. If the oil in the DR reservoir has not dropped much it will be OK to use on the road. It should make no difference when off roading. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Thu Jun 11 2009 8:38am |
Hi Angel,
Thu Jun 11 2009 8:41am |
Thank you all for your input.
Thu Jun 11 2009 9:12am |
Good to hear about the warranty claim and hope all goes well for you. Malaysia Boleh!
Thu Jun 11 2009 9:48am |
