Home > Technical > Sat Nav Voice |
muz1000 Member Since: 10 May 2009 Location: Sutton Coldfield Posts: 33 |
Does anyone know how to turn down the voice instruction on the sat nav she's shouting at me |
Tue May 26 2009 3:14pm |
When sat nav 'speaks' use the volume button on radio/steering wheel to lower volume. 2005 Zambezi TDV6 - Gone but not forgotten
Tue May 26 2009 3:22pm |
NoDo$h Member Since: 27 Mar 2007 Location: Darrrrrzet Posts: 88 |
Sadly Land Rover in their ultimate wisdom seem to think that if you are enjoying your Herb Albert collection at full volume, you want the trained chimp from the local radio station to interrupt you with useless information from the other end of the county at a similar volume, plus 1. Likewise shouty satnav lady.
Tue May 26 2009 3:53pm |
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 |
I am not vey familiar with the system, since I only have the car since last month (and most of all, I am swapping the original radio with an aftermarket unit.
Tue May 26 2009 4:41pm |
Press the soft menu button (bottom left)
Wed May 27 2009 7:43am |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 |
You can have the radio and nav voice at differential volumes. Next time the sat nav shouts at you when your radio/cd volume is up high, press the right hand hard button below the nav screen and use the steering wheel volume to lower the volume of the voice, the radio/cd remains the same Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Thu May 28 2009 5:45pm |
