Home > Maintenance & Modifications > brembo brakes
Page 3 of 3 <123
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Tim Hoang wrote:
I've had a set of Brembo calipers and tried to fit to mine TDV6 HSE but could NOT as the two bolts from the frame were different from the caliper (distance). Can someone tell me what modification I should do OR else??? Thanks.
Wrong calipers. There is no room for a mounting bracket between the strut and caliper (as with the non-Brembo calipers), so you have to get the right ones. Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #225629 Fri May 15 2009 7:14pm
Tim Hoang
Baron wrote:
My calipers look great. It's the centre hubs look s**t part silver and rust Embarassed
I will have a look see how many mm's are left on the pads coming off Thumbs Up
Too bone idle these days to change them myself Big Cry Used to in the old days Whistle
Hi, Can anyone tell me that a set of Brembo calipers from TDV8 will fit to my TDV6 ????? You can call me on 07894548688. I need to know ASAP. Thankss.
Post #225961 Tue May 19 2009 10:12am
simonsi
AFAIK they are the same. Cheers
Simon
Post #225973 Tue May 19 2009 11:26am
Tim Hoang
Sure??? Thanks
Post #225995 Tue May 19 2009 1:24pm
If you need definite confirmation, ring a dealer and get them to confirm. Then you can blame them if they give you incorrect info Wink
Post #226082 Wed May 20 2009 10:36am
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
leedsunited wrote:
Baron wrote:
Mine has gone in for second service this morning (2years 20k)
Stealer just phoned told me I need new pads on the front.
£285 Big Cry
I bet they have a load of wear left on them, get them on ebay or from LR dealer parts and change yourself or get a good independant, it will be a lot cheaper
I took mine in for a 3 year service and MOT a couple of weeks ago.
Got a phonecall from the Stealers;
"Your front pads need changing....they're 80% worn"
"That's funny" I said. "I checked them at the weekend and there was still 5.5mm left on them"
"Well, they're 80% worn, so they won't last until the next service"
"How thick are they when new?" I asked
"About 10mm" he said.
I wonder if he failed maths at school?
Oh, and when I got the car home, it dumped most of the windscreen fluid on the garage floor (cracked bottle). It took me half a day to replace it (on the upside, it was only £28 ). How the hell did they do that????
Mind you, that's nothing, on it's first service, the garage (different garage) managed to perforate one of the radiators, and had to replace 3 of the things before they stopped the leaks.
On the second service, got a call to say that one of the tyres had 3 punctures in it. Strange that, 'cos it had been sat in my garage for a few days, and it was fine when I set off, and the garage was only a couple of hundred yards down the main road! It might have had something to do with the back yard at the garage, which is covered in some sort of builders rubble!!!
Thinking about it, this all pales compared to An Audi TT I had a few years ago. 3 months old, it went into the Stealers for some minor job. They did so much damage to the car (on the ramps etc.) that they actually agreed to replace it with a brand new one!!
I wonder why I hate garages.............
Bob.
Post #226140 Wed May 20 2009 2:57pm
Tim Hoang
I rang Beadles in Sidcup and asked them, they said they could not provide any information. What can you do about it???
Post #226750 Tue May 26 2009 9:43pm
Page 3 of 3 <123
