![]() | Home > Technical > Is this normal??? |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Coko, the vibration in the steering could be the front diff. It was a bigger problem for the FFRR but i've seen a few on here that have had their diffs replaced after much investigation at the dealer. One of the topics when it was replaced is here.
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Cheers Hoppy.
If your car has been out of alignment for some while and then been realigned, it's possible your tyres have worn unevenly... this can introduce vibrations at various speeds? |
Good point mate... Do you think that the tyres will wear themselves back to even? |
In my experience, they certainly can do.... whether they will or not is a different matter |
Hmmm, was thinking of not using this car till Friday but you tempted me to give it a go and wear the tyres. But still worth having it checked, don't you think? |
RRS11 Member Since: 20 Apr 2009 Location: Seoul Posts: 45 ![]() ![]() ![]() |
Yes, I have and I did mention about this before somewhere in this forum. I still haven't figured about what's causing this "shaking" though. ![]() |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
Have you got Dynamic Response?
I have DR. It is really strange. Since I got the car in Dec 08 it was on winter tyres and I have not experienced it. However, ever since I swapped to summer the "shaking" has been there. |
ayates Member Since: 08 Jun 2007 Location: Houston Texas Posts: 369 ![]() ![]() ![]() |
I have the same shaking too around 55mph, will take to the dealer in a week or so.... driving me mad also...! Also had a re balance with no luck, perhaps alignment.... let us know how you get on Brit across the Pond |
Yep, defo ![]() ![]() 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
RonnieG Member Since: 16 Mar 2008 Location: Armagh Posts: 207 ![]() ![]() ![]() |
you could have a slight buckle in the wheel which will not balance out. also if the tyre has become deformed due to standing etc it iwll wobble when driving. what wheels do u have on. |
I have 20" with standard Contis on
your tyres are out of shape possibly due to a pothole or bad bump. unfortunatly it is a part of 4x4 ownership that will never go away. |
