![]() | Home > Technical > Is this normal??? |
RRS11 Member Since: 20 Apr 2009 Location: Seoul Posts: 45 ![]() ![]() ![]() |
First, vibration at certain speed. How fast were you going? I had similar problem with my previous car and did alighnment and balancing but it was still causing the problem. Then I found out sometimes you gotta do "high speed balancing". There was a prof tire shop in Chicago and they told me they usually do this for sports cars.
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
By doing what they have done (alignement and tyre swap) the vibrations seem to have cured. But as I will be going back to get the infamous knocking sorted (by exchanging the ball joints for the new redesigned; and bushings) I have time to observe it and report back.
