![]() | Home > Technical > Steering problems |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
EGR valve problems are all too common on the TDV6 |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
Similar issue to one i read about back in my bmw days. Have they replaced the g-sensor? (im not sure if this is the technical term ![]() I tried to look for the forum thread where someone had a similar issue but i couldnt find it. WINNER - 2008 Best All New Photograph WINNER - 2009 Best All New Photograph |
Hoye Member Since: 15 Dec 2007 Location: Tvedestrand Posts: 20 ![]() ![]() ![]() |
g-sensor? Well I know they replaced the ACE module some time ago. This week (I hope) they will replace the steering angle sensor. |
The car has now been with the dealer for one week. They will replace also the pitch rack? |
i remembered what it was called!
Yes, I think the yaw sensor is included in the ACE module that they replaced some time ago. |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
There are two yaw rate sensors in a RRS - one in the roof and one in the transmission tunnel. IIRC the lower one is used for DSC and they are both used (for comparative rates) in the ARM system... If either are faulty it may be thinking you are about to tip over on bends and will cut the throttle and apply brakes to individual wheels if necessary to avoid a 'roll-over'. |
OK, thanks. I will discuss this with the garage tomorrow. I was not aware of the one in the roof. ![]() ![]() |
