![]() | Home > Technical > does this make sense? ride quality? |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Are your tyre pressures the same as the '08 SC? |
SC is a better vehicle??? |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
SC has Dynamic Response as standard... |
buckblue Member Since: 30 Oct 2008 Location: Lebanon Posts: 144 ![]() ![]() |
will check the tyre pressures
Have you got Brembo front brake calipers? If so, you should also have Dynamic Response and, yes, it will make a difference as it evens out side to side bumps as well as keeping the car flat through the twisties. |
