Home > Technical > Speed Pulse Wiring |
M4RKUS Member Since: 06 May 2008 Location: london Posts: 9 |
not yet! Im a bit scared of cutting the wrong wire! lol |
Fri Apr 24 2009 2:02pm |
Fri Apr 24 2009 2:42pm |
mobile fidelity Member Since: 21 May 2007 Location: NSW Posts: 12 |
Using a DMM you can find the VSS at the ABS module under the bonnet. It's a Dark Green wire, but be warned, there are a few in the loom and you will need to test which is the VSS with the DMM. |
Sun May 03 2009 12:59am |
DTR Member Since: 29 Mar 2008 Location: Australia, ACT, Canberra Posts: 15 |
Some sellers of CAN bus demux
Mon May 04 2009 1:26pm |
